Old 07-14-2006, 03:58 PM   #1
otef546
Junior Member
4x4 rolling chassis new lower price
1970 GMC 3/4 ton rolling chassis. I plan on keeping the utility bad and scraping the rest of the body.The truck was built by Truck Equipment Company, it has a tag in the door along with the the GM tag with a date of 3-70 and a vin # .The chassis is complete except for the front driveshaft. Trans is a 4-speed, transfer case I believe is a np 205. The front end is a Dana 44 positrac, the rear end is dana 60 maximum traction both with 4.55 gear ratios.Refer to the pic of the options list. The truck has a P.T.O. coming off the 4-speed trans and goes to a winch on the front bumper. Also have all 4 factory 8" wide wheels. I was going to build a 4wd but have changed to a 2wd so I no longer need it.The truck is not running. The guy I bought it from said he was having trouble with the 307 motor and it quit so he parked it.I'm sure I have forgot some info or if you need more pics just ask. My job keeps me away from home for 36-40 hours at a time so please be patient with a response.I'm asking $800.00 Thanks Mike
otef546 is offline   Reply With Quote
Old 07-14-2006, 04:04 PM   #2
otef546
Junior Member
Re: 4x4 Rolling Chassis
more pics
Old 07-14-2006, 04:06 PM   #3
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Is the frame a long wheel base? Where is arkansas is beebe? Is all the electrical and braking functional?
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 07-14-2006, 04:17 PM   #4
otef546
Junior Member
Farmtruck, yes it is a lwb. I hooked up a battery and tried the head lights and they worked, didn't try much else but I can I you want me to.All the wiring looks to be there.The brakes are all complete but do not work, It does have power brakes.Beebe is about 30 miles north of Little Rock. thanks Mike
Old 07-14-2006, 05:30 PM   #5
farmtruckIII
71 GMC 454/TH400
A little too far from me (dang). Bump for a really cool old truck.
Old 07-16-2006, 03:07 PM   #6
otef546
Junior Member
ttt with a lower price. $800.00
Old 07-16-2006, 07:40 PM   #7
HOTFUN
HOTFUN's Avatar
Just curious about the axle ratios. Does the option list show 4:55 gear ratio as I can not see that in the option list picture? That Dana 44 posi front axle was an ultra rare option. If I was building one more that suspension and axles would be awesome combination. Thanks
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 07-17-2006, 12:02 AM   #8
otef546
Junior Member
Hotfun, I took the cover off the rear end and counted the ring and pinion teeth. 11 on the pinion and 50 on the ring. thanks Mike
Old 07-17-2006, 12:05 AM   #9
otef546
Junior Member
more pics of the options list
Old 07-17-2006, 06:00 PM   #10
wibilly
wibilly's Avatar
that a hell of a platform to build a bad@ss 4 wheeler
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-16-2006, 04:17 PM   #11
Nightrider
Nightrider's Avatar
cab come with truck ? still for sell?
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 08-17-2006, 07:34 AM   #12
otef546
Junior Member
rolling chassis is sold thanks
