Old 08-15-2002, 10:20 PM   #1
ryan68
Certified Chevy Man
ryan68's Avatar
Question Edelbrock 1405 Carb Questions
Just got a 1405 and my truck is at the shop, does anyone have this carb on their truck with a TH400 with the electric kickdown switch and does it mount to this carb?
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 08-15-2002, 10:33 PM   #2
68 Suburban
68 Suburban's Avatar
I put a 1406 on my 68 burb, and the kick down switch does not mount to the carb. Edelbrock does not have an adaptor. You can either get a kick down switch for a 71-72 which mounts on the gas pedal. Or you can go the aftermarket route.
http://store.summitracing.com/partdetail.asp?part=23745
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-15-2002, 10:39 PM   #3
ryan68
Certified Chevy Man
ryan68's Avatar
So where does the aftermarket kickdown kit attach to, the carb or the gas pedal? Do you have this kit?
Old 08-15-2002, 10:42 PM   #4
ryan68
Certified Chevy Man
ryan68's Avatar
Hmmm, I hope I got the right carb. The 1405 has the manual choke which attaches to a heat riser on the manifold correct? Or did I need to get the 1406 with electric choke?
Old 08-15-2002, 10:53 PM   #5
68 Suburban
Aftermarket will hook up to the carb.
Old 08-16-2002, 07:27 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
LOKAR has a really nice kick-down switch...about $60. After you get one of these, it won't matter which carb you run....you'll be able to make it work the 400TH.
Member Nr. 2770
