Old 12-28-2006, 10:03 AM   #1
Blackstone
Blackstone's Avatar
How low to go w/trailer in tow?
I'm leaning toward performing a 3/4 drop on my '73, but unsure which combination to use if I plan to occasionally haul a car trailer? If it matters, the truck is a 1/2-ton 2WD which will eventually become a SWB. Also planned is a set of 15X8 rallies, so will I need to consider control arm clearance in the front?
Blackstone is offline   Reply With Quote
Old 12-28-2006, 01:40 PM   #2
craig@ridetech.com
Formerly LSC71
Re: How low to go w/trailer in tow?
depending on how you will be lowering your truck the thing that will matter the most is how much spring rate you will have in the rear to keep the extra weight of the trailer suspended. There will not be any problem to tow with a lowered truck as long as you can carry the extra weight without the suspension bottoming out. On the front I don't know of a reason why you couldn't run the 8" wheel with the factory arms.
craig@ridetech.com is offline   Reply With Quote
Old 12-28-2006, 03:00 PM   #3
edman87
junk collector
put some ride bags or such in the rear to compensate for the extra load and drop it however you want.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 12-28-2006, 03:45 PM   #4
Blackstone
Blackstone's Avatar
Thanks guys, I think I've got it. Looks like the Firestone bags will do the job.
Old 01-03-2007, 12:14 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The 8" ralleys will only clear 2.5" spindles (mine are Western Chassis). The 3" drop spindles (like DJM) will cause the lower control arm to rub on the rally wheels.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-03-2007, 12:51 PM   #6
Blackstone
Blackstone's Avatar
Slonaker
Cool, I thought that I read that somewhere but couldn't retrieve the thread. I've located a 2.5/4 kit that I'll likely use. Thanks!
