Old 08-22-2002, 01:42 AM   #1
70blazer
70blazer's Avatar
Engine Bay Paint?
I am preparing my engine bay for my new motor. I want to know what is a good paint that will adhere to my firewall without peeling from the heat. I am planning on going with a flat black. Or gloss if someone tells me it would be better.
Help?
1967 Suburban, my kids call it the SuburBEAN cuz its long and green.
70blazer is offline   Reply With Quote
Old 08-22-2002, 02:04 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
i've had good luck with plain old rust oleum paint, just make sure you scuff the firewall first so the paint has a good surface to stick to.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-22-2002, 07:26 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
You won't have any peeling problems from heat in that area unless it's not prepped correctly. I've had good luck with Krylon if you want to go rattle can. If you really want durability, use an auto paint that you mix and shoot with a gun. I did mine in blue to match the body color but you can buy the blacks that you mentioned too.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
