Old 01-21-2007, 10:04 PM   #1
gator2511
gator2511's Avatar
Leaf Spring Bushing Removal
I just ordered new bushings for my front of the front leaf spring eyes and all of the rear spring eyes. The service manual says to use a press to remove and install the bushings. I don't have one but I do have a bench vise that opens up to 6" between jaws and I am wondering if that is enough to get the job done. What do you guys use for this and are they really that tough to change?
gator2511 is offline   Reply With Quote
Old 01-22-2007, 01:15 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Leaf Spring Bushing Removal
If you have access to a cutting torch, burn the old ones out. It's nasty and stinks up the shop, but that's how I have seen the pros do it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-22-2007, 08:22 AM   #3
Ozona
Just getting the leaf springs off my '72 has been difficult. Curious what tips you get, I'm at this step too.
Ozona is offline   Reply With Quote
Old 01-22-2007, 09:23 PM   #4
gator2511
gator2511's Avatar
I just added a lift block to the rear springs (1 1/2") and had to get new u bolts made locally. I'm hoping I can re use them when I pull the springs off. I have a buddy that has a big hydraulic press that I can use if need be. Just wondering if they are that tough to get out. I guess they must be.
Old 01-22-2007, 10:02 PM   #5
cdowns
cdowns's Avatar
burning them out is a easy way //you can use the vise or a c-clamp to install them // they'll go in a bit easier if you put them in the freezer overnight then a light coat of silicone grease
Old 01-22-2007, 10:05 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Yup. that's what my bro-in-law does. Even though he has a huge press, he burns the old out, and presses the new ones in. Freezing them helps too...
Articles-
"Refining Sierra"
Old 01-23-2007, 07:56 AM   #7
gator2511
gator2511's Avatar
Smile Re: Leaf Spring Bushing Removal
All right! That sounds like the info I need. Thanks.
Old 01-30-2007, 06:02 AM   #8
DESTRO
Any tips on removing them with the springs on the truck and no torch??
[man I know this jobs gonna suck!!]
DESTRO is offline   Reply With Quote
Old 01-30-2007, 07:17 PM   #9
rodnok1
rodnok1's Avatar
I drill the rubber out and chisel the rest out if I don't have a torch handy or can't use one. Use a bit small enough to fit between bushing and spring, drill all around the bushing. If you have to re-use the bushing be a little carefull to not muck it up. Usually you can use a small chisel to get more rubber out then wack the bushing out and clean up the rest. I'll do this sometimes if I don't wanna smell the burnt rubber.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
