01-28-2007, 11:30 AM | #1 |
another 5 lug ?
Ok on my 69, the previous owner added disc and drop spindles. However he left it six lug. Is there an easy way to convert it to 5 lug without having to buy a whole new kit? I would like to use as much stuff as I can that I already have!!
thanks Brad Walker www.gaugemagazine.com |
01-28-2007, 12:27 PM | #2 |
Re: another 5 lug ?
You can either buy new axles and drums or replace the rearend.
01-28-2007, 12:43 PM | #3 |
Re: another 5 lug ?
From what I've read, most 6-lug front disc kits utilize a blank rotor that would be for a 5-lug truck application that were instead drilled/studded for a 6-lug application.
Switching to 5-lug up front should be as easy as picking up a new set of 5-lug rotors @ your local parts house of choice. You should be able to verify this easily w/a board vendor (or pick up some 5-lug rotors & try it.... return them if they don't fit).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-28-2007 at 12:53 PM. |
01-28-2007, 01:00 PM | #4 |
Re: another 5 lug ?
Damn I need to start rereading posts before i reply. The fronts as SCOTI said and the rear as I said.
01-28-2007, 06:15 PM | #5 |
Re: another 5 lug ?
any idea of how to decide what they came off of, or what 5 lug vehicles rotors would fit?
01-28-2007, 08:53 PM | #6 | |
Re: another 5 lug ?
5-lug rotors that fit would (should) be 71-72 & 73-87HD truck rotors.
01-28-2007, 11:22 PM | #7 |
Re: another 5 lug ?
ok cool that is a good starting point. Do you think I could just take the rotors in to a parts store and have them figure it out?
01-28-2007, 11:41 PM | #8 |
Re: another 5 lug ?
Easy enough to do so it's worth a shot in my book. Do the rotors have any markings (P/N's) on them to possibly do a search on?
01-29-2007, 02:27 PM | #9 |
Re: another 5 lug ?
Where would they be located. I will try to find t hem tonight.
