Old 04-27-2007, 05:01 AM   #1
Curbstone Mech
Active Member
WTB:Alt brackets,pass side,swp
I need alternator brackets for a short water pump, passenger side set up that connects at the themostat housing, not the intake.
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 04-27-2007, 12:17 PM   #2
mal68ibu
Parts Hunter
mal68ibu's Avatar
Re: WTB:Alt brackets,pass side,swp
Did the factory make such a thing? I thought all of the short water pump engines had the alt. on the drivers side.
1968 Chevelle 300 DLX (350 4 speed)
1984 GMC 2500 6.2, 700r4 work truck
1967 GMC Custom (was 6.5 Turbo Diesel powered)
My ebay Store: http://stores.ebay.com/The-Musclecar...3aFQ3aSTQQtZkm
My website:http://themusclecarshop.net/
1967 GMC 6.5 TD conversion build:http://67-72chevytrucks.com/vboard/s...d.php?t=290922
mal68ibu is offline   Reply With Quote
Old 04-28-2007, 08:08 AM   #3
Curbstone Mech
Active Member
The p.o. added pwr steering and moved the alt to the other (pass) side.
You're probably right, no such animal from what I can find. For $ 35 or so I can get a long h2o pump and use aftermarket brackets. As long as I can hook up the ps pump, I'll be better off. Thanks for the reply
68 short fleet
700r4 351;1 posi
Old 04-28-2007, 05:32 PM   #4
70GMC396
I need the same thing. My factory A/C set up was one the pass. w/ the PS and ALT on the drivers - short water pump. I ditched A/C and am moving ALT to passengers side. But I can't imagine a bracket setup using the thermo housing to bolt to since it is on the drivers side more than passengers. White performance's swp has lwp bolt locations added to it, btw. I am asking them right now what the best approach would be.
70GMC396 is offline   Reply With Quote
Old 04-29-2007, 02:19 PM   #5
k5keith
I have acouple of th upper brackets . I'll dig through some boxes and see if i can find the lowers.
k5keith is offline   Reply With Quote
