Old 04-30-2007, 08:14 PM   #1
BigTruckDriver
BigTruckDriver's Avatar
Having a little trouble sizing up rims on 89 suburban/ 22?
The guy at the tire shop set the rim up on the truck but it did not fit, well it did but he had to use a 1" spacer. The area where it mounts to the spindle would not fit .It was not deep enough, thats why we used the 1" spacer. Dont know if I should keep them and use them with the 1" adapters , or send the back . You guys running your rims with spacers?.
Didn't know if this was the right place to post this, so if its not can a Mod move it.
BigTruckDriver is offline   Reply With Quote
Old 04-30-2007, 09:58 PM   #2
bedsled71
bedsled71's Avatar
Re: Having a little trouble sizeing up rims on 89 suburban/ 22?
well first off. i wouldnt run a spacer on a rim . but if you must then make sure you have enough threads on your lugs exposed. you dont wanna just have half an inch of threads to work with. i work at discount tire and we cant even work on vehicles with spacers because we are a large company and they say spacers are a liability issue, does it not clear the suspension or are the wheels center bore too small for the hub?.. i would say to get the right wheels for your application
bedsled71 is offline   Reply With Quote
Old 05-02-2007, 10:09 PM   #3
BigTruckDriver
Ya , I told the guy to get the right rims yesterday. I have not heard back from him yet.
Old 05-03-2007, 10:14 PM   #4
cajundragger
Re: Having a little trouble sizing up rims on 89 suburban/ 22?
so the hub bore was too small? are the covered or exposed lug? If their covered you can have your rims run on a wheel lathe and have the CB made large. Nissan and yota guys do it all the time to run escalade wheels...
cajundragger is offline   Reply With Quote
Old 05-03-2007, 10:42 PM   #5
BigTruckDriver
I thought of that but it was actually the hub bore was not deep enough to clear the spindle. The center cap would not pop in. They actually look pretty good with the 1" adapter but I have 2 trucks(89 sub,65 Chevy) and would like to have the option of having a couple inches back spacing (1 maybe 2) to play with.
They aint the greatest but I like them.
Old 05-04-2007, 07:52 PM   #6
cajundragger
I getcha, thats weird.
