04-30-2007, 11:08 PM | #1 |
It's the air up here
Hole in my gas tank
I just found a hole in my gas tank, it has been repaird with some kind of putty. What do you guys think I should use to fix it better? The hole cant be bigger than a pencile.
eedgell
1971 cheyenne k10 4 speed np 205 454 BB factory a/c Never drink down stream of the herd! Eric |
04-30-2007, 11:20 PM | #2 |
Watch out for your cornhole !
Re: Hole in my gas tank
JB Weld works real well in cases like that. If it's not leaking now though, I'd leave whatever is on it there.
04-30-2007, 11:38 PM | #3 |
The patch is leaking. Had to siphon the gas out of the tank, now need to fix right.
eedgell
04-30-2007, 11:46 PM | #4 |
Jb Weld works great. I had to fix the tank in my 84 ranger like that. There was a hole from where the wrecking yard drained the tank. I found a metal piece (used to plug/cover holes in electrical conduit boxes) that was similar in size and glued it in. Just make sure the surrounding area is nice and clean and it should last al ong time.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
05-01-2007, 12:22 AM | #5 |
I found something new to me this weekend. I had a small hole in my water pipe and could not get to the cutoff becuase it was to far out of reach. I cut off the main water and used some plumbers putty to patch it. When it dried it was like a rock and when I turned the water back on no leaks, still not leaking. This stuff comes in a plastic tube and you cut off the amount you need and nead it for about a minute and put it on. It will get rock hard within a hour.
This is my best friend |
05-01-2007, 01:43 PM | #6 |
If your tank is a behind the seat type many post with those type for sale or give away are useually posted.
11 Surbaban 70 C 10 still in progress |
05-01-2007, 03:41 PM | #7 |
lots of stuff to use / marine-tec, jbweld,porpatch all work good on gastanks just clean and degrease the area to be patched real well and you'll get lots of years out of the repair
05-01-2007, 04:09 PM | #8 |
Rottenwood Garage Member
I have JB-weld on just about every tank I have.......its holding on all of them,
05-01-2007, 04:45 PM | #9 |
jb-weld that stuff is invaluble to a gear head.....had it on my waterpump entire time ive owned my truck and its still holding strong
05-01-2007, 05:36 PM | #10 |
The Older Generation
Too bad you are in CO I just took a good one out of a '72 you could have if you wanted to come & get it...... LockDoc
