Old 09-12-2002, 02:18 AM   #1
TheMattMan
Drop question on a 72 lwb
I am going to buy a 3/5 spindle kit from early classics and have a question on the stance. I noticed in there catalog the drop still leaves the rear end sitting a little higher than the front. Would a 6" drop in the back level it to the front? Or is there anything else that could be done to create a level drop...Giving that this truck will never haul anything again in its life...
TheMattMan is offline   Reply With Quote
Old 09-12-2002, 07:04 PM   #2
low 84
low 84's Avatar
are the tires on the early classics truck the same size front and rear? it probly has smaller ones on front which causes the front to sit a little lower. if you run the same height tires front and rear, it should sit about level.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 09-15-2002, 03:21 PM   #3
73GMC
Proud American
leveling
you gotta figure that truck come higher in the rear to begin with due to the fact that they are setup to be load-bearers in the rear. all you have to do is compensate for this. figure that a 4/6 drop will get it even, a 3/5 should accomplish the same i would think because the height difference is usually right around 2-2.5" lower in the rear. if nothing else, ask the company about it.
good luck!!
73GMC is offline   Reply With Quote
Old 09-16-2002, 10:00 AM   #4
TheMattMan
thanks for the replys... I will get in touch with them.
MEMBER OF THE DRUM BRAKE CLUB
