Old 06-15-2007, 10:29 AM   #1
Chevelle454
Chevelle454's Avatar
Question Where do I find these....
I am trying to get my tail lights wired up so I can finally drive my truck today for the first time, but I have a problem. I have the wires from the tail lights going all the way up to the cab, but I don't remember where they plug into the cab. I can't find a connector like the one coming from the tail lights anywhere. It was four years ago that I took it apart and took pictures of everything but that pretty much...
Any description of where it plugs in or pictures would be helpful. It's a 1972 C20 350 auto.
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 06-15-2007, 10:47 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: Where do I find these....
Should be on the firewall to the pass. side of the steering column iirc.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-15-2007, 10:49 AM   #3
RyanG
RyanG's Avatar
RyanG is offline   Reply With Quote
Old 06-15-2007, 10:50 AM   #4
3/4tonterror
3/4tonterror's Avatar
hole next to the throttle linkage on firewall.
3/4tonterror is offline   Reply With Quote
Old 06-15-2007, 10:56 AM   #5
Chevelle454
Yeah, the hole is there...but there is no connector there. Even under the dash I don't see anything. Any idea where it's supposed to splice in to the rest of the wiring? I may just have to hardwire....
1972 C10
1972 C20
Old 06-15-2007, 11:08 AM   #6
Chevelle454
Here are pics of the holes in the firewall and the plug that I have...
1972 C10
1972 C20
Old 06-15-2007, 11:08 AM   #7
John Fabris
TOTY 2006
John Fabris's Avatar
Should be a small round plug with 4 connectors (2 horizontal, 2 vertical) and it should be hanging under the dash. I can take a picture of the plug today if you need it..
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-15-2007, 11:17 AM   #8
krue
Designated A-hole!
krue's Avatar
If I'm not mistaken it goes in the hole that you have the clear tubing running thru
www.daveramsey.com
Old 06-15-2007, 11:29 AM   #9
1lowdiesel
1lowdiesel's Avatar
just check under the dash for the same color wires then splice them in.
this should help you out.
http://www.geocities.com/chevroletc1070/wiringdias.html
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 06-15-2007, 12:25 PM   #10
Chevelle454
Smile Re: Where do I find these....
I found the problem... I had the speedo cable in the hole for the wires... I ran the speedo to the correct hole near the master cylinder(it fits much better, I'm an idiot...). The wires were jammed back behind the firewall heat/sound material. Thanks for the quick replys...
Scott
1972 C10
1972 C20
Old 06-15-2007, 02:08 PM   #11
cdowns
cdowns's Avatar
just a reminder to install a ground strap between bed and frame so your lights will work
Old 06-15-2007, 11:22 PM   #12
sdkid
Yep, definately need those. When I bought me '68 20 years ago, Bubba had a ground prob and drove nails between the box and frame to solve it.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 06-15-2007, 11:41 PM   #13
corn
Thats a good thing to know! I think Ill go with ground staps instead of nails though.
corn is offline   Reply With Quote
Old 06-15-2007, 11:56 PM   #14
Chevelle454
Yeah, I have had some problems with my tail lights so I will have to put that ground strap in too...
1972 C10
1972 C20
