Old 06-24-2007, 09:23 PM   #1
Ram-Man
Ram-Man's Avatar
power steering pump shaft styles?
Does anyone know what years or style power steering pumps have the keyway shaft on them? I want to use all billet pulleys and most catalogs say only with keyway shaft.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 06-25-2007, 07:30 AM   #2
Ram-Man
Ram-Man's Avatar
Re: power steering pump shaft styles?
Anyone?
Old 06-25-2007, 12:45 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here is a copy/paste by Shane that I found on search.
Shane
Von Dutch Lives!
Re: Power steering pump help?????
there is absolutely NO difference in the pumps between a small block or a big block for our model trucks, the difference is in the brackets ONLY.
early style (late 50's thru mid 60's) pumps had 3/4" in shafts with NO keyway and the pulleys were pressed on.
later (mid 60's up) style pumps had a 1/8" keyway in the pulley ... unsure of shaft size, this was pretty much the standard pump until GM went to the serpentine pulley/belt system ... and some claim the only difference then was the pulley, I can't say.
I have a ZOOP'S press on 3/4" shaft single groove pulley if you are interested, it is polished billet FORGED aluminum , not the Cheap Chinese cast version.
Let me know if you're interested & I can get you a pic or two.
Keep On Truckin'
Shane
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
