Old 06-25-2007, 11:19 AM   #1
jorgensensc
jorgensensc's Avatar
Power steering pump Question?
Are all the power steering pumps the same for short water pump vs long water pump? I have a March SWP bracket and wanted to get a pump from the j-yard and they all seem to be for LWP. If I take the bracket off the pump, and put mey bracket on, will it work? Is there a pulley difference (besides key way, non keyway, adnsingle/double groove/serpentine, metric, o-ring, and remote resevoir)? Thanks for the help guys!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-25-2007, 11:21 AM   #2
Shane
Shane's Avatar
Re: Power steering pump Question?
I think the only difference is the brackets ...
Shane is offline   Reply With Quote
Old 06-25-2007, 12:09 PM   #3
kxnomore
kxnomore's Avatar
I don't think they are all the same. I had some belt squeal issues, and finally tracked it down to the power steering pump not fitting correctly in the brackets.
It was the short water pump style, and when I got the new pump, it was clearly different in the reliefs molded into the body where it attaches to the brackets.
The old pump was not fitting in the cradle exactly right, and was causing the pulley to be slightly crooked. The new pump fit perfect and all the squealing was corrected. Hope this helps.
kxnomore is offline   Reply With Quote
Old 06-25-2007, 03:27 PM   #4
jorgensensc
Now I'm even more confused. I don't know if the recesses will matter because of the way the bracket mounts (very simply munts to the two outside bolts on the pump). I am almost stuck. I can get one off a lwp truck at the local salvage for 20.00, but it has brackets and all, but the hoses are bad. I only need a pump, pulley, and hoses. I don't know whether to get a two groove or single groove since I don't know which will line up. I'm so confused!!
Shawn
Old 06-25-2007, 03:43 PM   #5
dmsteele92831
When I converted I wasn't sure either, but I went with the two pulley (I think in case you have air) and it worked great. I also matched the years of the pump and gearbox together (mid-80's)
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
dmsteele92831 is offline   Reply With Quote
Old 06-25-2007, 04:16 PM   #6
jorgensensc
Okay, talked to cpp this is what they said. SWP/LWP, no difference in power steering pump. Bracket only. Up to '77 uses flare, '77 up uses metric or o-ring. Pulley doesn't make a difference. So I guess I only need a puley now.
Shawn
