Old 07-23-2007, 11:31 PM   #1
jorgensensc
jorgensensc's Avatar
Wood bed strip Question?
Hey all,
I got the Stepside bed off the truck and all torn down to start the paint and bodywork prep. The steel strip that holds the wood down that is connected to the side of the bed is rusted and I want to replace it. I have seen the new ones being sold, but can't figure out the best way to remove the old one. It looks as if it is spot welded the whole length. How do you install the new ones, especially for you polished stainless steel strip guys. Do you go back and spot weld the new ones in? Let me know what the best coarse of action is!
Thanks !
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-23-2007, 11:44 PM   #2
drivethechevy
drivethechevy's Avatar
Re: Wood bed strip Question?
well i havent goten that far on my truck yet but i have the same problem
from looking at them it looks like mine unbolt then slide out as a whole unit
idk if urs are different or if im wrong about mine but they are for shure bolted in on my 68 fleetside
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 07-24-2007, 08:49 AM   #3
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
Mine were spot welded at first, I removed them with a hammer and chisel, bad idea, got little dents now. drill the spot welds down through the strip and they should pop off rather easier. I still havent replaced them yet.
OlChev67 is offline   Reply With Quote
Old 07-24-2007, 06:24 PM   #4
mbgmike
Originally Posted by jorgensensc View Post
Hey all,
Thanks !
Shawn
They do make covers to go over the old ones. We sell them. You can take a air hammer and chisel if you feel comfortable using one. You can drill the welds out also If you replace them with Carbon steel angle strips you can weld them on or bolt them on to the sides. If you buy stainless one they are usually bolted on to the sides but you will see the bolts. It is possible to weld the stainless to the sides but you would have to have the skill to do it.
mbgmike is offline   Reply With Quote
Old 07-24-2007, 09:33 PM   #5
jorgensensc
Ttt
Old 09-23-2007, 08:34 PM   #6
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Would like some Info Also...............
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 09-25-2007, 12:38 PM   #7
mbgmike
Here is a link to Mar-K with info about the angle covers.
http://mar-k.com/catalog/catalog.asp...19721972CS-145
You can purchase them from us or Mar-K
On a regular stainless angle strip
I have thought about (have not done it yet) welding some short studs on the inside of the bed to bolt the strips on from the inside. Maybe weld the stud to a small thin plate from behind, then tack that to the bedside. Then the bolts won't show on the outside. it would have to be pretty thin to look ok though. I have thought about gluing them to the side also using body panel adhesive. (maybe I am nuts).
Old 09-25-2007, 02:52 PM   #8
chip46wis
I air chiseled mine off then hammered and dollied the sides---about 25 spot welds from the outside holds them on nicely-----Make SURE you note which end is which---they are different from end to end.Check hole location before removing the old ones---------
chip46wis is offline   Reply With Quote
Old 09-27-2007, 05:48 PM   #9
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
MAR-K also has instructions on removing/replacing the angles:
http://www.mar-k.com/54-72anglestrips.pdf
Hope that helps!
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
