07-29-2007, 12:32 AM | #1 |
anyone got the wiring scematic for a 71 gas gauge
hey im real tired of not knowing how much gas is in my truck and the time has finnally come to fix this little demon..so anyone on here who can help me out?
Hvy71
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
07-29-2007, 12:47 AM | #2 |
Re: anyone got the wiring scematic for a 71 gas gauge
The wire is a cream colored wire that plugs into the fuse block. It runs along the dr door channle under the silver sill plate. It then runs along the top of the tank to the sending unit. Check this wire first as it is easily damaged by the sill. If it checks out check the fuel sending unit in the tank. As they are natorious for going bad. If it checks out with an ohm meter then it might be the gauge. Then it is a remove replace on it. Hope this helps and good luck.
07-29-2007, 10:12 AM | #3 |
Active Member
Another test I've done: Once you determine if the wire to the sending unit is plugged in and is good. Then try putting it to ground to see if the gas guage moves.
If it doesnt, you may still have a both a bad guage and sending unit. As Aaron mentioned, suspect sending unit first. I've replaced 2 or 3 in my trucks in the last 15 years. The problem occurs when you don't drive them a lot and water in the gas corrodes the unit. |
07-29-2007, 12:05 PM | #4 |
where does the cream colored wire plug intio the fuse block? cause that wire is hanging loose
07-29-2007, 12:45 PM | #5 |
72 chevy
Theres a blade in the fuse block that says fuel ga it plugs in there its at the top center of the fuse block.
Ed |
