Old 08-03-2007, 02:15 AM   #1
12volt
66 Chevy Vortec V8 5 Spd Buildup
New to the board and wanted to share my 66 project.
66 Chevy Truck Fleetside longbed, small window, 98 Chevy Brakes and spindles (still 6 Lug) on the front. Just took out the factory 3 speed and carb 350. Working on getting the Vortec 350 with NV4500 5 speed transmission in. i have both motors out just need to get the vortec in. Hopefully I will get it running this weekend. Here are a few pics
Out with the old.
In with the new.
I am also going to install a 14bolt semi-floating rear end and the factory gas tank from the 98 as well as the factory a/c.
Debating on getting a hypertec programmer or spending the money for EFI Live or not. Any sugesstions? I also have a full set of autometer gauges for the dash along with the billet aluminum gauge cluster. I will post more pics soon.
I am welcome to any suggestions. THanks!
12volt is offline   Reply With Quote
Old 08-03-2007, 02:42 AM   #2
hewlett2002000
hewlett2002000's Avatar
Re: 66 Chevy Vortec V8 5 Spd Buildup
very very nice. i like. any chance we could see some full truck and inside pics? i live in lake worth, TX. good luck and keep up the good work.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 08-03-2007, 02:44 AM   #3
12volt
I will post them up. Its ugly though. Edited by Moderator My shop is in Lewisville.
Old 08-03-2007, 02:57 AM   #4
12volt
Drivers Side, Just installed 98 Chevy Truck 60/40 Seats.
Pass Side
Old 08-03-2007, 03:12 AM   #5
hewlett2002000
good lookin ol truck. mine looks about the same. mines parked for a while though. im fixin some stuff up to get it more drivable and safe.
John
Respect:
Old 08-03-2007, 03:13 AM   #6
hewlett2002000
o and btw i might have to get me a seat like that, i like the way it looks in there.
Respect:
Old 08-03-2007, 03:35 AM   #7
hewlett2002000
all i have are when it was still on the truck. ill take closer ones tomorrow.
Respect:
Old 08-03-2007, 05:11 AM   #8
krue
Designated A-hole!
krue's Avatar
Welcome to the board! Been thinking about the vortec swap myself. However no buying/selling/trading allowed unless your a Subscribed member and then only on the parts board. For info on subscribing click the "support the board" link in my sig.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-03-2007, 09:09 AM   #9
Slowmotion
Nice seats. Just curious what is that trans out of?
Slowmotion is offline   Reply With Quote
Old 08-03-2007, 09:12 AM   #10
64GMCHorsepower
Justified!
Will the fuel tank fit easily under the bed? Is that where you are going to put it?
Nice looking project you have going.....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 08-03-2007, 11:01 AM   #11
12volt
The transmission is from a 98 2500 chevy truck.
The gas tank fits in width. however, it is too long. I might chop off the end of it. Don't know just yet.
Old 08-03-2007, 06:27 PM   #12
Woogeroo
12volt - I'd like more info on those brakes... if you have the time.
-W
Woogeroo is offline   Reply With Quote
Old 08-03-2007, 09:19 PM   #13
12volt
On the brakes I took the entire spindle, hub, rotor assembly and used the factory 66 lower ball joint on the factory 66 lower control arm. I had to use the upper ball joint for the upper control arm from the 98 Van. However, the spindle is about 1 inch taller than the factory 66 and the camber is way off. Therefore, you must either build a custom upper control are or a custom lower control arm and adjust the length about 1" Right now I just have the factory arms on until i get the motor in then I will build custom arms. Basically I am using the design off the StrongArms that are used for air bag systems. I will have my upper arms adjustable via threaded rod and right hand threaded heim joint. I am doing the extra work because I think the brakes of the newer trucks are a whole lot better then the 72-88. They are 6 lug too!
Old 08-04-2007, 04:04 AM   #14
63 & 64 Bowties
and a few others
Pass Side
how's that seat workin' out? leg room & seat height okay?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 08-05-2007, 12:43 AM   #15
12volt
The seat height is no worse than stock.
Old 08-05-2007, 08:28 AM   #16
1963chevyshort
New Member
1963chevyshort's Avatar
Looking good
Anthony
63 chevy stepside SWB
57 chevy 2dr hrdtop belair
1963chevyshort is offline   Reply With Quote
Old 08-07-2007, 04:17 PM   #17
12volt
More pics
old motor
new motor
