![]() Join Date: Sep 2002
Best sand to use in a sandblaster
Just picked up a used Snapon sandblaster and was wondering what the best sand to use in it would be, and where to get it. I tried buying some playsand but it wouldn't work. Any help or suggestions are appreciated.
Thanks. Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: Best sand to use in a sandplaster
is this a cabinet if so you dont want sand// if its a regular out in the open blaster , no the play sand usually has too much moisture in it , you need to get 00fine bagged blasting sand, places i've found it are paint and auto body supply shop, large tool rental companies, building supply companies(not lowes or home depot) masonary supply companies. if you have a harbor frieght stor near you they carry a few types of nonsand blasting media
MOST IMPORTANT IS BREATHING PROTECTION AND EYE &SKIN PROTECTION at all times
![]() Join Date: May 2002
I've used DuPont StarBlast. It works well and eliminates alot of the problems associated with using more common sand.
'72 C10 Short Fleet "Praise the Lowered" |
Rolled on Paint Club
![]() Join Date: Jan 2006
I use the Black Beauty coal slag media that I get at the local Napa. Works great.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
never finish start another
Don't use John Wayne sand. It won't take crape off anything
Buy mine from the local headstone company.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Thanks to all, it is an outside type, basically a plastic bucket on wheels with a hose to a gun which sucks the sand out. Nothing happened with the play sand at all. I figured it was too large of a grain.
Scott
i have used several different kinds, the black dimond being the most agressive fastest. some i have gotten i needed to screen. it was to course and plugged my nozel frequently. i use a presureized blaster and there is no comparisome to my old siphon blaster. the presurized is atleast ten times faster
common sense isn't so common anymore |
![]() Join Date: May 2006
Don't let your hose lay on the ground, it will pic up condensation and clog your sand. Something to do with inside friction [heat] and outside temp. Dry sand is the key to a nonpresserized system. Also try to keep your bucket as high as you can, let gravity work for you. Just a thought, I don't do that very often, must not be a CRAFT day. J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-05-2007 at 07:48 AM. |
ditto, used it for my frame $10-12 per 100 lbs bag. Their website will tell you the companies in your area that carry it.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
