Old 09-24-2002, 04:28 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
Question Horn Relay
My horn never has worked. Is the relay the little square block that is screwed to the drivers side of the core support?. I figured it's cheap and might be the problem.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 09-24-2002, 05:33 PM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Yep, that's it. If it's working, you should hear it click when you push the horn button. If you can't hear anything, either there is no power getting to it or it's bad. Test it for power.
If it is clicking, your horns are probably bad. Test wires for power at the horns.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-24-2002, 06:22 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
Isn't the horn relay an aluminum cased relay bolted to the inside fire wall around the steering column? Just above and to the left of the column? The only thing I remember being on the core support is the voltage regulator and the horns themselves.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 09-24-2002, 08:23 PM   #4
barn9
Half a bubble off!
barn9's Avatar
My horn relay is on the inside of the firewall, at the base of the steering column. O.T., but related, one of my horns quit working, is there something in there that goes bad? Never messed with a horn in my life, so I don't even know how they work.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 09-25-2002, 08:38 AM   #5
bobs409
bobs409's Avatar
Oops! I think you guys are right. Im picturing one of my Chevelles. That's what I get for owning 6 oldies!
Well, in any case, where ever it is, see if it clicks...
Bob
Old 09-25-2002, 09:00 AM   #6
JimKshortstep4x4
Smile
I have never seen a horn relay go bad in these trucks. Usually it is the horns. Sometimes you can make them work by smacking them with a rubber hammer with power to them. I have also made them work by adjusting them. The adjustment screw is very small and it has a different head on it. Anyway it adjusts the points inside the horn. The points seem to stop making contact because of not being used. Just turning the screw back and forth will usually get the horn to working again. You want to have power to the horn when adjusting.
Jim
Old 09-25-2002, 09:28 AM   #7
Blazer1970
Blazer1970's Avatar
My horn relay was bad when I got the truck.
Blazer1970 is offline   Reply With Quote
