Old 08-06-2007, 05:50 PM   #1
hewlett2002000
hewlett2002000's Avatar
a few questions........
ive been posting my questions in separate posts so im just gonna ask them all here. here it goes...
what is a good replacement for the stock accelerator setup? i would like a cable set up.
i am changing fro my Saginaw 4spd to a th350. will a powerglide crossmember and yoke work on the th350? if the glide crossmember will work can i bolt it where it would go stock on my truck or does it need to be in a different location?
how hard would it be to put the e-brake in the floor? (just an idea)
is there any 6 lug rotors for my disc brake setup in the front?
when i change to power brakes will the rod on the brake pedal be too long or short to go in the booster? what if i just use a master cylinder from a disc/drum car or truck?
thats all i can think of right now. i appreciate any help you can give.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 08-06-2007, 05:57 PM   #2
David Flores
David Flores's Avatar
Re: a few questions........
For the accelerator setup and floor ebrake setup, check out Lokar Performance.
http://www.lokar.com/
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 08-06-2007, 07:01 PM   #3
layinrocker65
layinrocker65's Avatar
just about any company that sells disc brakes for are trucks, have rotors in 6 lug. There usually more that the 5 lug though.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 08-06-2007, 08:56 PM   #4
rodnok1
rodnok1's Avatar
I put a acc pedal setup from a camaro in, there are several threads on here about cable swaps/even a no weld swap.
You may have to change location in brake pedal, the stock location doesn't give enough throw. You will prob need adj rod also.
You prob can find 6 lug rotors/what it may take some checking/you need to figure out what bearings you now have and see what 6 lug rotors call for same bearings.
check out the link to my homepage(panel progress pics), it may help you out with other things.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 08-06-2007, 09:43 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
thanks,
John
I have a powerglide crossmember holding in my 700r4 with my TH350 tranny mount. So in other words. Yes the powerglide crossmemeber will work with the TH350 tranny...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-07-2007, 10:27 AM   #6
mbgmike
Thats what I used in My 65. We are dealers for Lokar.
Mike
mbgmike is offline   Reply With Quote
