08-07-2007, 08:04 AM | #1 |
A guy with a truck
Gringoloco's GenIII 6 point-oh build
Well, I finally found the time to start on this project I've had sittting around for a while. A buddy of mine (Fastrucken) has a '66 fleetside he is currently doing a 5.3/4L60E swap into. He also turned me on to a 6.0 sitting in the JY where he got his motor. I couldn't resist the deal for $400- take whatever you need! I got everything- sensors, harness, accessories- all of it.
It has been sitting a while until he started doing his swap; I just couldn't let his truck be cooler than mine So, I started the unenviable task of tearing through all the spaghetti and getting into the very DIRTY motor.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-07-2007, 08:14 AM | #2 |
A guy with a truck
Re: Gringoloco's GenIII 6point-oh build
I decided after getting into it, that the motor needed freshening up. I have taken a little time to clean everything well as I go and will be doing a few upgrades along the way. The rotating assembly is mostly stock except for the ARP rod bolts- notoriously weak in these motors- the bottom end should be good for 600hp now. I won't be making quite that much, but while I'm in here I will definitely be making some heads/cam improvements. Looking for around 450...
In these pics you can also see the Trans-Dapt motor mount plates I'm using as well as the 73-87 style 'clamshell' mounts I'm switching to. I had planned on using the ECE style, but felt it placed the motor too far forward for my tastes.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 08-07-2007 at 08:55 AM. |
08-07-2007, 08:41 AM | #3 |
A guy with a truck
That's what it looks like now, after disassembly, cleaning, honing, more cleaning, new bearings/rings, a coat of paint, and reassembly. Waiting on my heads and cam now.
I also started tearing into the harness. I figure for $600 for an aftermarket harness, I can do this on my own. It really is pretty simple once you get into it. The harness is basically stand-alone already, you just need 4 fuses and 3 relays added to make it run. I will take some time and reroute it while it's apart because the way the trucks harness is from the factory runs over the intake and to the fenderwell- UGLY. It's much more manageable when it's not balled up on top of the motor. I got it pared down to only what is needed to run. Out of the 160 pins on the ECM, I will only need 52! For whatever reason, the only tape I could find while labeling the harness was expensive a$$ blue painter's tape. At least it wasn't the green stuff... The box of wires is what I deleted from the harness. Here's also a pic also of the engine that's coming out. It's actually a pretty good running little 350ci. I think I'm gonna put it in my truck. My ol'lady asked me why I was doing this when the truck already has a perfectly good engine. I asked her why she needs so many pairs of shoes... They'll never get it, I guess.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 08-07-2007 at 08:48 AM. |
08-07-2007, 09:57 AM | #4 |
nice job.... so are your using the exisiting 350 or 400 tranny?
you get rid of the tranny, neutral saftey sw., rear o2's wires and there goes about half your wireing... |
08-07-2007, 06:57 PM | #5 |
A guy with a truck
I'll be putting a 700R4 behind it. Minus those circuits and all the emissions junk makes for a really clean setup.
08-08-2007, 12:11 AM | #6 |
Questionable
what kind of adaptation is involved with using a 700R4?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-08-2007, 02:53 AM | #7 |
A guy with a truck
Not much really. Just have to find a way to actuate the TV cable and a crank spacer to line up the torque converter. The spacer is off the shelf GM. Bowtie Overdrives makes a kit if I can't easily figure anything out for the TV cable. I'm thinking I can use the old cruise control bracketry...
08-08-2007, 10:37 AM | #8 |
08-08-2007, 11:00 AM | #9 |
Questionable
Is it easier to use a 700R4, or a TH350 for a swap like this?
How much of the harness can you whittle away if you use an analog tranny (and delete rear OČ's)? I thought the 700R4's were notorious for grenading. I always hear 3rd Gen Camaro owners complaining about their trannies taking a crap on them (all 700R4's) I am pretty sure internals were beefed up when the 700R4 went electronic (became the 4l60e), but ... I can't help but wonder if that 700R4 is going to hold up behind an LQ9?
08-08-2007, 01:51 PM | #10 | |
Global warming is a myth
Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
08-08-2007, 08:30 PM | #11 | |
A guy with a truck
08-08-2007, 09:02 PM | #12 |
Can you tell me more about the motor mount setup.
I had to cut the engine stands off my 68 cause they were all hacked up. I'd like to use motor mounts that have the bolts running parallel with the frame, so what engine stands, motor mounts, and adapters do I need for an LS1? |
08-08-2007, 10:53 PM | #13 |
Questionable
I would get the tubular mounts that you see in Killer 71's buildup. All you need is a mount with a single bolthole parallel to the frame.
08-09-2007, 01:37 AM | #14 |
I agree that's what I'm using
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
08-09-2007, 05:40 AM | #15 | ||
A guy with a truck
These are the red and blue PCM connectors on a truck. Some of the extra unused pins will be diffrerent between F-cars and 'vettes. The highlighted yellow portions are must haves for the engine to run: - Idle Air Temperature Sensor (IAT) - Crank Position Sensor (CKP) - Fuel Injectors - Throttle Position Sensor (TPS) - Knock Sensors (May run without them, but why?) - Cam Position Sensor (CMP) - Ignition Coils - Oxygen Sensors O2 (Front- rears are emissions only) - Manifold Absolute Pressure sensor (MAP) - Mass Airflow Sensor (MAF) - Idle Air Control Motor (IAC) - Engine Coolant Temperature Sensor (ECT) The highlighted green are extras I will be using for convenience: - ALDL Serial Data to hook up a scanner - Fuel pump relay control - Tach output - Alternator turn on - MIL/SES Lamp - VSS Signal (helps with idle w/auto tranny and output for speedo)
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 08-09-2007 at 07:28 AM. Reason: Wrong Pic |
08-09-2007, 05:58 AM | #16 |
A guy with a truck
And some progress- Got it bolted together some more and started routing the wiring harness. I will be hiding the wiring as much as possible. I want to be able to see my valvecovers! I will also be doing some coilpack relocation to hide them a little better than just sitting on the motor.
08-09-2007, 09:08 AM | #17 |
makin some headway i see!
R.I.P. Killer 71 10/26/07 |
08-12-2007, 03:11 PM | #18 |
On board, . The only truck "stuff" I brought with me to NM was the 5.3 wiring harness for the CrewCab. I don't have a garage or many tools, but thought I might be able to figure out how to make the original harness work and save a few bucks. Do you know what wires you keep if you are going to run the factory 4L60E?
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-12-2007, 09:44 PM | #19 |
A guy with a truck
As far as I can tell, the highlighted red are the only ones needed to run it. This is untested and unverified, but all that is left are emissions and various fluid level sensors and traction control, but who needs that stuff?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 08-12-2007 at 09:53 PM. Reason: Dumbass forgot the pic. Doh! |
08-12-2007, 10:32 PM | #20 |
Re: Gringoloco's GenIII 6 point-oh build
you'll also need "33 brk sw ppl"
08-12-2007, 11:03 PM | #21 |
like this....
http://216.25.99.66/newhtml/brakeswitch.html |
08-12-2007, 11:15 PM | #22 | |
Does this dude know some stuff or what?
08-13-2007, 10:31 AM | #23 |
A guy with a truck
08-13-2007, 11:21 AM | #24 |
08-18-2007, 05:57 PM | #25 |
this is some usefull info. Thanks alot!
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
