08-27-2007, 04:58 PM | #1 |
What should I do? Help me decide!
Ok I will try and keep this short but
I need to thin out my fleet and I am trying to think of the best way to go about doing that with and loose the least amount of money at the same time. Three vehicals in question are as follows. 1) 70 Low Buck (I am keeping this one) but changing around a bit. 2) 71 Slow build SWB, body dropped, bagged, all metal has been done and it is ready to finish up. The motor combo is a 92 Vett LT1 with sanderson custom build headers, Painless RPM computer and harness, 700R4 built for 700hp from a small block with a 2300RPM converter, 12bolt with 3:73's and an Eaton Posi all new never run on the road as of yet. Custom built SS 35gal fuel tank with vette in tank pump $1300. All brand new "67-68" trim for the entire truck still in the box's. 67-68 front end with a forward tilt hood, duel electric fans from a newer camero. 17x11 with 335/35/17's out back and 17x8 (or 9"s) with new tires as well never run. 3" Drop spindles, disk brakes, power brakes and Power steering. Bucket seats out of some import that are in good shape with custom seat brackets for the truck. 3) 70 factory 2WD Blazer. 350 and a granny 4spd, runs and drives but not really drivable with out some work. I have all the replacement panels needed to end up with a clean original body. Ok so here is what I am thinking, pull the motor and tranny out of the 71 and put in it to Low Buck (I have spent over 8K on this combo) as well as put the 67-68 front end on thier as well with all the new trim ($1600). Then put the stock (in great shape) 71 front end back on truck. Then pull the 5lug suspention out of the 71 and put it in the 2wd blazer along with the motor out of Low Buck (new 350 carbed with a 350 auto). I would then put the 6lug stuff off the blazer on to the 71 and sell it as a body dropped roller (not sure if it would be bagged or just stock springs). Then with the blazer I would put in the good 350/350 combo out of Low Buck along with the front and rear suspention ( minus air bags maybe) and the 17" tires and rims. I would use the front end off of Low Buck with the 67/70 hood, do all the sheet metal work and most likly paint the blazer as well and sell it as a freshly built frame off factory 2WD Blazer (with a crappy) top. My thoughts are by doing this I would keep the more expensive drive train ouit of the 71 since I would not see that money in return when I sell it un finished. By swapping everything else over to the blazer and finishing it up I fell it would sell much faster and for more money than the truck would. So what it comes down to is I have too many projects ( I only listed 3 out or 9), not enough room or extra money to build and keep all three of these. So by selling the 71 as a roller I would use the parts and money to finish the blazer then sell that to start to fund another project in the works. Give me your feed back but do not ask for prices or to buy any of the vehicals as I am still in the planning stages. If you want please let me know what you think the two vehicals would be worth as I have discribed them. You have all seen my work and these would not be any less quality just because I am doing them to sell and not keep. Kevin LFD Inc. |
08-27-2007, 05:20 PM | #2 |
Re: What should I do? Help me decide!
PM Sent
08-27-2007, 07:29 PM | #3 |
Boy did I luck out. I just checked with my local parts store and the Blazer tank I used is an 89 set up for TPI and the 92 LT1 in tank pump will fit the blazer sending unit All I need to do is run a return line and I will be all set up to drop the lt1 into Low Buck.
Well I will talk to you all this friday as I am leaving town for work untill then so have a great week and figure all this stuff out for me by then would ya! Kevin LFD Inc. |
08-27-2007, 07:39 PM | #4 |
The problem if you swapped all the stuff on project Low Buck you would make a killer truck but would negate what you were trying to show the general public with it. That you can build an awsome truck for x amount of dollars
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
08-27-2007, 07:53 PM | #5 |
laying low
WHAT? Do you have any idea how long it would take you to do all that? What is your time frame for this? Dude, you gotta sleep sometime.
I agree the most expensive item you have is sitting in slow build and it's nowhere near ready to drive out so pulling it for one of the other ones, sure. If the Blazer drives sell it as is and just swap the engines between the other two if need be? I guess selling off a couple of the other projects is out of the question? Bronco, etc.. you won't miss it, really..
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-27-2007, 08:26 PM | #6 |
How long it would take Rockcrln to do it - maybe a Day and 1/2!!! Working at a slow pace and taking a lot of breaks.
Us mere humans, 2-3 years...working a couple hours a day of pure dedication with no days off. Remember the vehicles he builds for others in his spare time. He does not need sleep... he is Rockcln, King of Fabricators. (Note: I am doped up on antihistimines and feeling a little goofy, please ignore the previous post. It was all meant in jest and fun)
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) Last edited by Primered_69; 08-27-2007 at 08:27 PM. |
08-27-2007, 11:05 PM | #7 |
Moderator
This is fun! My vote: keep Low Buck exactly that-low buck. That build is an inspiration to daily driver's everywhere. Keep the LT1 and goodies for the Blazer and get a good start on it with the dough from the '71 roller. You'll have two killer trucks, and then in the future if you want to go wild with Low Buck you can reinvent it. Thanks for the poll, I usually just get to dream with my own money!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
08-28-2007, 01:37 AM | #8 |
sounds like alot of work to still not have a compleated project. imo low buck is by far the most useful and i like it the way it is. adding all that computr controaled crap just defeats the reason many of us like these simple old trucks. i think it is right at home where it is. you have 3 great vissions here, i would finish them one at a time rather than put all that effert into changing things around to still not have a finished truck
common sense isn't so common anymore |
08-28-2007, 04:11 AM | #9 |
It was great followin low buck build, so I say that since low buck build is finished for all intesive purposes, and your plans are to keep low buck build then do the motor swap that you were talking about. Put that killer motor in low buck since you are going to keep it anyway. The rest is up to you. All I know is that when I win the lottery your the man who is going to build my truck.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
08-29-2007, 02:51 AM | #10 | ||||
Time, I can have the motor swap from Slow build to Low buck in and running in about 3-4 days with the front clip being done at the same time. Suspension from Slow build to the Blazer and back again would be about 1 maybe two weekends (roller to roller). All the sheetmetlal work on the blazer would be another 2-3 weeks ready for blocking and paint. Quote:
My other thinking is both the blazer and Slow build need about the same amout of work to finish (with in 40hrs of each other) but the finished truck would still get about 30% less then for the same work in a factory 2wd blazer at least here in Cali. Kevin LFD Inc. Last edited by Rokcrln; 08-29-2007 at 02:54 AM. |
08-29-2007, 07:41 AM | #11 |
Well looks like you figured out what you are going to do
08-29-2007, 10:13 AM | #12 |
I think I have but lately I have been changing my mine like my son's diapers. They even start to smell the same from time to time Even I have a good idea what direction to go in you all are still a great sounding board to double check ideas! Thanks
Kevin LFD Inc. Last edited by Rokcrln; 08-29-2007 at 10:14 AM. |
08-29-2007, 10:53 AM | #13 |
GEARHEAD
Sell the blazer as is. Let it be someone elses project. Swap the drivetrains in the trucks if you want that combo in low buck as your regular working truck. Slow build, will be just that, slower. Sell something else out of the 9 projects and move on.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
