Old 08-27-2007, 05:07 PM   #1
bryanw1968
bryanw1968's Avatar
My cheap fan build......
Ebay this setup for $129.00. The relay was like $29.00 from Moroso.
I really like this setup.
bryanw1968 is offline   Reply With Quote
Old 08-27-2007, 05:09 PM   #2
bryanw1968
bryanw1968's Avatar
Re: My cheap fan build......
Sorry forgot the pics!
Old 08-27-2007, 05:23 PM   #3
Ole Blue 68
Ole Blue 68's Avatar
That is purty...
Ole Blue 68 is offline   Reply With Quote
Old 08-28-2007, 10:56 AM   #4
bryanw1968
bryanw1968's Avatar
Nice. I'm all bragging on the stupid thing and it quit working on my on the way home yesterday. Truck got up to 240 degrees breifly. Turns out the fuse was too close to the radiator and melted. I bout the plug in stile/waterproof to replace somewhere away from the radiator. Doah!
Old 08-28-2007, 11:37 AM   #5
71see10
Worthless
71see10's Avatar
Looks good and clean!!!Got the same set up, very Pleased with mine!Keeps everything cool,better than the clutch fan.Now with that said lets hope she dont quit!!
71see10 is offline   Reply With Quote
Old 08-28-2007, 12:54 PM   #6
70c10
67-72 Addict!
70c10's Avatar
What are these fans out of?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-28-2007, 01:52 PM   #7
bryanw1968
bryanw1968's Avatar
They're not out of anything. Got em' brand new for $129.00 offa ebay.
I can't find the exact link but here is something very similar from another company.
http://cgi.ebay.com/ebaymotors/Flex-...QQcmdZViewItem
Old 08-28-2007, 03:00 PM   #8
71see10
Worthless
71see10's Avatar
Got mine from (skipwhite) performance off of ebay!!Have not looked to see if he has more listed!! But he gives there ph. # on his listing page.
Old 08-29-2007, 02:38 PM   #9
bryanw1968
bryanw1968's Avatar
Ever since I replaced the burned up fuse holder/fuse with the new setup I'm blowing fuses. So, I replaced the fuse and disconnected one of the fans to see if dropping the load would help. It did. Right now I'm only running one relay and I think optimally I should be running one relay per fan right?
Old 08-29-2007, 03:10 PM   #10
71see10
Worthless
71see10's Avatar
That is probably the problem,the relay I bought was made for daul fans and had two fuse blocks with it, both of mine are 20 amp fuses.So far I have not had any problems but I have up graded to a 100 amp internal reg. alt. I was maxing out my factory alt. with fans,air cond. and lights. I will look tonight to see what kind relay I have (at work right now). Hope this may help! Brian
Old 08-29-2007, 04:50 PM   #11
bryanw1968
bryanw1968's Avatar
I'm running a Bosch I got from my speed shop but I think they have the same one at autozone. I'll check tonight and wire in a separate one.
Are you running a thermastat? Currently I am not but will at some point.
Old 08-29-2007, 08:38 PM   #12
71see10
Worthless
71see10's Avatar
Yes,It is adjustable,You just wait until your thermostat open up (by feeling the rad. hose ) then turn the knob until the fan comes on!! I found where I bought mine at, it was at oreilly auto parts(HAYDEN COOLING PRODUCTS - FAN CONTROL (ADJ THERMOSTATIC) $33.24 part #3647 They had different ones but the manager is a freind of mine (Has a great looking 67 step side)and he told me about this one!
