08-28-2007, 10:01 PM | #1 |
Is a c-20 frame and a c-10 frame the same?
Are they both the same? If not whats different? I searched but didn't find the answer.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
08-28-2007, 10:03 PM | #2 |
Designated A-hole!
Re: Is a c-20 frame and a c-10 frame the same?
Essentially the same, I believe I've read that the 3/4 ton frame has a little more bracing, but they can be swapped with no issues iirc.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-28-2007, 10:16 PM | #3 |
Ok cool thanks, thats exactly what I wanted to here.
08-28-2007, 10:17 PM | #4 |
its all about the +6 inches
you'll need to use 3/4 ton cab mounts too, the mounts on the frame are mounted lower.
08-28-2007, 10:20 PM | #5 |
I wasn't swaping cabs or frames, a may be buying a c-20 but I want to do the disk brake 5 lug swap. Did c-20s have leafs or coils?
08-28-2007, 10:21 PM | #6 |
ok cool
C/20's could be had either way... the semi-rule of chevy = coils and GMC = leaf still apply... remember, if it's a longhorn, it'll have leafs regardless. |
08-28-2007, 10:25 PM | #7 |
Ok cool cool ya its a chevy but I'll just have to look. Thanks again for the help guys.
08-29-2007, 02:20 AM | #8 |
The other thing to remember is that a 3/4 ton truck frame with coils will not interchange with one that had leaf springs, Or is it the rear ends that won't interchange?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
08-29-2007, 09:37 AM | #9 |
Next project: 1970 K10
Anything can interchange with a welder and grinder
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
