Old 08-29-2007, 02:17 PM   #1
panelguy
panelguy's Avatar
3/4 ton rear end???
A friend of mine is doing some work on a 71 3/4 ton 4x4. He thinks the rear end is out of a 1 ton dually. He would like to put in the correct rear end. Will one owrk out of a 73-87 3/4 ton 2wd???
66 Acadian 2 door
69 GMC panel truck
78 Chevy crew cab dually
79 Chevy blazer 2wd
01 Chevy silverado 2wd reg cab shortbox
panelguy is offline   Reply With Quote
Old 08-29-2007, 02:32 PM   #2
Duel72
Re: 3/4 ton rear end???
It probably is the original rear axle. I have a '72 3/4ton with a Dana 60 dually rear axle from the factory.
Duel72 is offline   Reply With Quote
Old 08-29-2007, 02:56 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a DRW rear end is the same as a SRW.
Old 08-29-2007, 04:36 PM   #4
1969 GMC
1969 GMC's Avatar
I think the DRW rear ends are narrower due to different hubs.
A 73 and up 3/4 ton axle will work, but you will need to move the spring perches. I forget how much, a search should turn it up.
and a DRW rear dana 60? I want to see pics of this.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
