Old 09-04-2007, 09:35 PM   #1
goldengoat2
disc brake master cylinder
Finishing up a 4x4 disc brake conversion on my 67, can I use my non dics brake master cylinder, or do I need to change it. Thanks
65 tripower conv 4spd gto, 66gto, 67 gto
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
goldengoat2 is offline   Reply With Quote
Old 09-04-2007, 09:50 PM   #2
CHRIS67GMC
CHRIS67GMC's Avatar
Re: disc brake master cylinder
Change it.
CHRIS67GMC is offline   Reply With Quote
Old 09-04-2007, 10:01 PM   #3
Ackattack
Ackattack's Avatar
yeah, change it. Disc brakes require more fluid flow than drums.
Ackattack is offline   Reply With Quote
Old 09-05-2007, 11:47 AM   #4
Musclerodz
Also need to change the prop valve to a disc/disc valve or install an adjustable one
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 09-05-2007, 06:51 PM   #5
Smitty
Smitty's Avatar
The drum master holds more residual pressure than the disc unit does. Found out the hard way. Had a drum master on my '71 bled it out and couldn't turn the rotor because of the difference in the residual pressure.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
