09-27-2007, 05:28 PM | #1 |
Sierra Grande Club
Putting clay on piston to check valve clearance.
Can I use clay to check my valve clearance? Anyone recommend this?
Open to opinions s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
09-27-2007, 05:30 PM | #2 |
Re: Putting clay on piston to check valve clearance.
Engine builders been doing it a long time.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
09-27-2007, 05:30 PM | #3 |
yes just measure the depth of the clay where it is compressed.
09-27-2007, 05:57 PM | #4 |
i always used silley putty
09-27-2007, 06:05 PM | #5 |
unless you,ve got a hi-compression engine with a hi-lift cam you dont need to worry about it.
I BELIEVE IN JOHN 3:16 |
09-27-2007, 06:05 PM | #6 |
Sierra Grande Club
Yes- good suggestion it won't leave any residue.
s/t
09-27-2007, 06:07 PM | #7 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 09-27-2007 at 06:08 PM. |
09-27-2007, 06:26 PM | #8 |
yes be better be safe then sorry
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-27-2007, 09:22 PM | #9 |
IMHO it's worth doing all of the clearance checks just to learn how to do them...and good insurance besides.
09-27-2007, 10:43 PM | #10 |
you,ll have alot of clearence with 10-1 and that small of amount of lift cam. now if your going to 550 lift and more with thin head gaskets and cutting your heads down to 58cc,s or lower then thats another issue. and that cam is hydraulic lifter cam too right ? that opens up another can of worms. and i,am sure your not going to run it so hard you,ll float the valve train. your thinkin hard core racin measurements. also your not running dome pistons are you ?
bob
09-27-2007, 10:44 PM | #11 |
"Trucks with Class"
A light valve spring and dial indicator is a much better way to do the checking. You can keep checking the clearance at the rocker arm every 10 degrees as you rotate the engine, with all of the valve train angles and if you have close clearances, you will know exactly where it is tight...in/ex///opening or closing.
09-27-2007, 11:44 PM | #12 |
I would check it. Longer duration has a lot to do with it too, not just lift. The piston chases the exhaust valve. If the valve is hanging open for a while, the piston will catch it. Not good. I use the checking valve springs like PICKMUP suggested. I just push down on the rocker while rotating the crank over (by hand) until the piston contacts the valve. I continue until the piston pushes the rocker up to max lift. Then I use a dial indicator to verify clearance. Once the dial indicator is set up, I rotate the crank back and then forward to find the minimum clearance.
