Old 10-10-2007, 01:28 PM   #1
1987_3/4ton_chevy
Cowboy Up
Lift Kit for '68 2wd
Guys, i have been looking for a lift kit for my 1968 3/4ton 2wd... and having a heck of a time finding one! Does anyone know if they even make such a thing for this truck? I looked all over and having been able to find one. Need some help finding one, thanks!
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 10-10-2007, 02:03 PM   #2
streetstar
streetstar's Avatar
Re: Lift Kit for '68 2wd
would probably have to adapt one from a '73 - '87
does the 3/4 have leafs ?
as always, a 2" body lift can top off anything too
streetstar is offline   Reply With Quote
Old 10-11-2007, 02:54 PM   #3
1987_3/4ton_chevy
Cowboy Up
Yes my truck has leafs on it...
Chris Cary
Old 10-11-2007, 03:02 PM   #4
earl87gta
earl87gta's Avatar
you can use any 4x4 rear springs for it but the front is not the easy no kit is avalable. your best bet may be to find a 3/4 or 1ton front suspentoin to put on it. or finda set of custome coli springs to rais it some but I would think your only going to get an in or two. the 2wd drive kits for the newer trucks have raised spindals to get the lift no one makes them for our trucks.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-11-2007, 03:25 PM   #5
1987_3/4ton_chevy
Cowboy Up
darn so what websit would be the best to look at one?
Chris Cary
Old 10-11-2007, 03:34 PM   #6
earl87gta
earl87gta's Avatar
you on it for the 3/4 stuff and one ton stuff try to pm BCOWANWHEELS he is parting a 1ton and grendel may be too maybe they can measure ther coil springs for you.
Earl
Old 10-11-2007, 04:55 PM   #7
1969k10stepside
Check with fabtech,you could modify a 2wd lift from a 73-87 to use..
1969k10stepside is offline   Reply With Quote
Old 10-11-2007, 06:21 PM   #8
earl87gta
earl87gta's Avatar
if he went that way he could just get the new style cross meber and all the front suspention I know some of the 2wd convertion guys use them in the 67 to 72 trucks and he could get the stuff cheap from a salvage yard.
Earl
Old 11-30-2007, 05:12 PM   #9
FingerTight
So there I was...
FingerTight's Avatar
I went with stock BB springs in a SB front end...gained about an inch and it rides a bit stiffer...ymmv
- Rick
1969 C10 LWB, leafs, 350/700R4,
2003 Yukon Denali
FingerTight is offline   Reply With Quote
Old 11-30-2007, 06:45 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Look at my 3/4 ton 2wd. It has local spring shop leveling springs in it. 150 dollars per pair, custom made. It's damn sure lifted a good bit...
Old 12-03-2007, 08:23 AM   #11
pooz911
pooz911's Avatar
I have rancho springs installed. They are equiv to 1 ton springs. ball joint spacers, 3 inch body lift and 33 inch tires.
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
