Old 11-01-2007, 10:20 AM   #1
stope4
Brakes - Combination Valve
Has anyone ever rebuilt one of these? Does anyone sell original rebuilt?
stope4 is offline   Reply With Quote
Old 11-01-2007, 10:57 AM   #2
cdowns
cdowns's Avatar
Re: Brakes - Combination Valve
i dont believe they are rebuildable// 10years or so ago they were available new from gm dealers
Old 11-01-2007, 11:52 AM   #3
Orange
Licensed to Thrill!
Orange's Avatar
Early Classic sells these if this is what you are talking about:
http://earlyclassic.com/catalog.aspx
(Can't give a direct link - just go to brakes in their catalog, it's on page 2 I think).
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 11-01-2007, 01:11 PM   #4
grayw0lf
Chevy Duty also sells them.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 11-05-2007, 03:34 PM   #5
stope4
For some reason, the early classic one looks slightly different than the two I have. Has anybody ever tore one apart, cleaned it up, replaced the o-rings and reused? If you did, did it work correctly afterwards?
Greywolf, I do not believe there is a ChevyDuty.
Old 11-07-2007, 05:00 PM   #6
stope4
I tore into one of the two of these I have this weekend. Suprisingly, these things are pretty simple. Looks like all you need are o-rings and a good cleaning to get this thing running smothly again. Does anyone have information on the proper sized o'rings. I went to O'Reilly's and tried to match them. They had o'rings that were the same overall diameter but the problem is the combination valve uses o'rings where the rubber itself is different diameters. Need some expert knowledge here.
Old 11-14-2007, 04:24 PM   #7
stope4
O.K., I had to hunt for the o'rings but I finally located the correect sizes. Does anyone know where I can find the v-cup seal that is located under the big bolt on the end of this contraption. I think it's mainly used as a dust seal but not 100% certain.
Old 11-14-2007, 05:11 PM   #8
john
member #16
john's Avatar
You should make sure the seals are compatible with brake fluid.
john is offline   Reply With Quote
Old 11-14-2007, 10:44 PM   #9
stope4
They are. The place I purchased them said they needed to be EP o-rings.
