Old 11-15-2007, 02:48 PM   #1
crawdad
crawdad's Avatar
A/C compressor cycles in all positions
Saw another thread similar to the question I'm wanting to ask, but thought I'd start another thread. My AC compressor cycles in every position except off. I knew they were suppose to in the defrost position, but I didn't think they were suppose to in Heat, Vent, ...every position except off. What's going on here and has anyone tackled a similar problem before. What's the fix?
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 11-15-2007, 02:57 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: A/C compressor cycles in all positions
Sounds like a bad Pressure Cycling Switch, the switch is mounted on the Accumulator.
Malo83 is offline   Reply With Quote
Old 11-16-2007, 02:02 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I think your dash controls are bad. Mine runs the compressor when it is on vent. I have a new set of AC Delco controls. One of these days I will install them and see if it fixes it.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-16-2007, 05:22 PM   #4
crawdad
crawdad's Avatar
Slonaker
How hard of an install is this. Do you have to fool up with a lot of vacuum lines or is it pretty straight forward?
Old 11-17-2007, 09:55 AM   #5
Slonaker
Slonaker's Avatar
I think the vacuum lines come off in groups, but I'm not sure. I haven't done it yet.
Slonaker
Stock '01 Silverado
Old 11-17-2007, 12:49 PM   #6
firedrag79
firedrag79's Avatar
The control is pretty straight forward to replace.... once you can get to the back of it. The vacuum hoses should come off as one unit and can only go on one way. There were 2 lock type washers (for lack of the proper term) that hold them on. I just got done switching mine out of my old 85.
1988 Crew Cab SWB project
firedrag79 is offline   Reply With Quote
