350 builds??? Tell Me What You Got!
I am about to build a mild 350 for my 70 stepside. I would like to know what heads and camshafts you guys are running on the street... I have a 4 bolt main and I will be running .040 flatops.... I am thinking some Vortec heads... Billla is already pointing me in the right direction, I just have to get there!
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
Re: 350 builds??? Tell Me What You Got!
350 + .060, flat tops w/ 4 relief valves, vortec heads, compcams 262xe kit, edelbrock performer rpm, 650cfm holley vaccuum secondary. I modeled this after reading "the goodwrench Quest" where they took a gm crate motor and tried to see how much power they could make. According to the article, this combo should put me in the 350hp+ range. the article is online, so if you googled "goodwrench quest" it should come up.
Thanks, I am on the net looking ofr the article...
I've been loving my 270H cam!
I'm very happy with what I've come up with. It's very mild mannered on the street, yet has plenty of grunt. Last edited by Jim_PA; 01-04-2008 at 03:59 PM. |
Go with vortec heads with a lt1 cam.For the $$ it will haul a$$!
A used lt1 cam can be had for $50
krazy hillbilly from Kentucky
Which LT1? The old one or the new one? The new one can only be used with a roller block, or you can have the specs ground into a hydraulic flat tappet.
1969 Chevy CST/10 "Old School lives and breathes in the heart of a chosen few ![]() 1984 Chevy C10 Silverado "Life, Liberty, and Ford's Pursuit of Chevy taillights" You say "Obsessed with my trucks" like it's a bad thing |
I was running a 350 4 bolt, .060 over flat tops 4 vr, with 1970-71 400 heads, fully ported, 1.94/1.60 valves, 76cc chambers, 292H cam(292/292*, .501/.501"), solid lifters, Magnum roller tipped rockers, upgraded 1.47" springs. I have pics and those heads are for sale with just under 8K miles on them. The only thing I don't suggest is that cam...it's too big for idle and vacuum quality.
Machinist
I am running a 350 2 bolt, .060 over flat tops ,cast crank with a set of441 heads, fully ported,polished, angle milled, screw in studs guid plates 2.02/1.60 valves, 305H cam , 1.6 Harland sharp roller rockers, cut for bigger springs. I love big cams put a little timing in them and run a big converter mines a 5300. a blast on the street and 200 shot from nx dosnt hurt either
Keep them coming, I am going to plug all this into a spreadsheet for future examination...
