the boat guy
quicker ratio steering box
are their any aftermarket companies making a quicker ratio steering box, or another vehicle with quicker steering that i could bolt on or make fit with little modification?
![]() Join Date: Feb 2001
Re: quicker ratio steering box
Wes has them...Look here...http://www.classicheartbeat.com/67-72_chassis_2.htm
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
I have one, it bolted right in.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
the boat guy
thanks.
sweet deal, but i have a 67 and the quick ratio seems to be for the 69-72, is their a difference, will i still get the $75 for my 67 core? |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Call Wes, He can answer all your questions
![]() BTW the variable ratio has less turns lock to lock. I'm running the variable ratio redhead gear. |
mine is a 67 also. I believe that the reason for the 69-72 is becuase they switched the powersteering for those years. I think the 67-68 had a "power rod" of some sort that attached to the drag link. So for the resto nuts and not to get calls saying it's completely different than the one they want to replace, they designate what year it's correct for. Just about everything mechanical will switch between years.
So, if you have the "standard" type powersteering box, I'm sure you will get your core back. If you have the "rod type" of power steering, you can sell it for more than the core value.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 01-28-2008 at 01:10 AM. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
The quick ratio steering gears are for the 69-76s. The reason that I didn't include the 67 2wd and 67-68 4wd is because you will have to modify your frame to bolt it on. The 68-72 2wd, and 69-72 4wd chassis have an indention to allow for the larger diametered power steering gear. You can modify your chassis on the 67 2wd, and 67,68 4wd to accept it, but it is not a stait up bolt in part for those. If you go to my 67 panel project build up pages in our website, you will see how I did the modifications to it. Here is a link: http://www.classicheartbeat.com/67_panel_project.htm To answer about the $75.00 core charge, you will have to have a power steering gear to use for the core. Hope this helps. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Out of the carpool lane.
Just to help out a bit, I have raised mounting holes on my '67 frame, but still no indentations. So I just used 3 washers on each hole for the gearbox to clear the frame and have had 0 problems for years. Also, I used a quick ratio gearbox off a '77 quad cab truck. It's 3 1/4 turns lock-to-lock. I can literally steer with my pinky, however some consider that ratio to be 'twitchy' and too fast.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
I did that swap where I used 1/4" hardened cat washers, and ran into the twitching you are talking about. The twitching is caused by moving the steering gear outboard of the frame further by the 1/4". What that does is make the steering gear off center. The steering gears all have a center, or "nutral" spot so that when you drive down the road, slight movements of your hand won't cause your vehicle to vear one way or the other. That is what the 1/8 turn or "play" back and forth is, in your steering wheel that doesn't move the wheels when the tires are pointing strait forward. When the gear is off center, you are off to one side of that play or nutral spot when your wheels are pointed strait forward, because now the gear is off center. Causing the steering geer to be actuality slightly in a turning possition when your wheels are pointed strait. Dent the frame and bolt the gear right against it like it was designed to be bolted that twitching will not happen. I hope I didn't confuse anyone, because I almost confused myself...
Has anyone ever ground a hole in the frame instead of pound a dent? Seems like that might work, too.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Thanks for that Wes! That made perfect sense to me. It's not bad, and I've gotten used to it, but others have mentioned on here that they don't like that feel. However, I drove rental cars for the first 6 months of last year. It took me a few weeks to get used to my truck again after that.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 01-28-2008 at 03:08 AM. |
Your welcome Brad, I am happy that I could help.
dan42, I would think that you would weaken the chassis if you did that. I suppose if you used some sort of reinforcing plate on the backside of the frame it would work. Lots of flexing goes on there...lol WES
#13 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#14 |
Just a quick question. Are the quick ratio boxes that you are refering to straight 12.7:1 Gear Ratio?
72 SWB parts and pieces Oklahoma |
#15 |
![]() Join Date: Nov 2006
I see both "quick" and "variable" ratio steering boxes offered at the Classic Heartbeat link. What would be the difference or advantage of one over the other?
#16 | |
Collector of Projects
I want less turns lock to lock but I don't want it to turn faster and be twitchy. What it the stock power steering ratio for a 72 K5 Blazer and what are the ratios for the two different boxes? |
#17 |
I've had all 3 on my 67 (standard, quick-ratio and variable).... my recommendation is the variable. It progressively gets quicker. So it's not twitchy on the freeway and doesn't take as many turns to go thru the drive thru.
Got the Redhead from Wes. I'm very happy with the Redhead, other brands have leaked or slack has developed quickly. Been about 2 years and all is well. |
#18 |
To add to what Classic Heartbeat said, you absolutely want to have the gearbox centered when you are driving straight ahead. If you do a PS conversion that mounts the box on a spacer you can achieve this by adjusting the tie rod sleeves. However, this leaves you with unequal left and right turning angles at full lock, so is kind of a kludge.
Ray |
#19 |
I have a variable on my longhorn(love it). The only time its twitchy, is sliding sideways over 100 mph(dont ask), but yes she has done that
http://community.webshots.com/user/hotrodhorn |
#20 |
Classic Heartbeat's explanation of centering the gearbox has a flaw.
The idler arm on the other frame rail and the pitman arm on the gear box must work in conjuction and swing in parallel arcs. The distance from the center line of the pitman shaft to the machined surface on the inside of the gear box is not the same for the manual box and the power box. If you assumed that distance to be the same on the two boxes you would be in error. If you lay the old '67 manual box on its side, on a flat steel surface and measure vertically to the center of the pitman shaft, you will find that the manual box is 3/32" greater than the power box. Because of the bulge in the power box you will have to place measured blocks under the machined pads and subtract that thickness from the pitman measurement. Adding one each, 3/32" washers to the stack, gave me the exact same measurement. I ground the casting flash off the power box and tack welded the washers on the frame. I chalked the box and put it up against the frame. I ground the high areas from the box and a little from the frame until it fit. Wasn't really that much. I didn't want to put a hole in the frame and I didn't want to heat it past cherry red to get the dent the size Heartbeat has. I used the same gear box Brad used. The extra long wheelbase four door, chassis cabs and long beds, wouldn't be able to get around a corner with a regular ratio box. It is not twitchy. It changes lanes on the freeway without oversteering or causing any concerns. It works great in close quarters for parking and backing a trailer. I quickly added a smaller steering wheel, because you don't need that big wheel anymore to muscle it around.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 10-19-2010 at 10:28 PM. |
#21 |
I dont see the "variable" box on that link anymore. is it still available from Wes?
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 |
