02-23-2008, 11:09 PM | #1 |
Addicted to Chevy
glove box latch removal
Okay, how does this thing come off? i bought a new liner and have been trying to see how to remove the latch. I have included pics so you can circle some hard-to-describe parts if necessary
crap... i misspelled on the heading... now i look stoopid Last edited by chev74; 02-23-2008 at 11:10 PM. |
02-24-2008, 12:09 AM | #2 |
Re: glvoe box latch removal
thats a good question, mine fell off one day so i picked it up and put it back together, well i never could get it apart again, so , i just went and got another glove box door.
02-24-2008, 12:42 AM | #3 |
Addicted to Chevy
i just need the thing to fall apart so i can put it back together!!! the PO cut the bottom plastic 'hinge' where it bolts to the dash
02-24-2008, 01:38 AM | #4 |
I think you have to stick a sharp object in that little slit and push in on a latch that holds it on. I went through this onece before. Took me a while but figured it out. The people at Texas Auto Salvage didn't even know how so I figured it out myself and they had been working there for umpteen years. duh!!!!!
02-24-2008, 01:49 AM | #5 |
im going to have to go home and try it out, if i can find the lock
02-24-2008, 02:49 AM | #6 |
Addicted to Chevy
figured it out!!!!!! Follow the pics
02-24-2008, 04:04 AM | #7 |
Dark Heart Motorsports
chev74 .... you are awesome... I am soooo archiving this page!
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
02-24-2008, 06:57 AM | #8 |
Addicted to Chevy
this is the first time i have ever been able to help someone else!!!
02-24-2008, 07:37 AM | #9 |
02-25-2008, 09:51 AM | #10 |
Re: glove box latch removal
Chev74, you're the man!!!!!!!!! I tried getting that thing off a year ago and then put it to the side for a rainy day. I guess it's raining, I'll go pull it off now. Thanks
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
02-26-2008, 08:32 AM | #11 |
Addicted to Chevy
glad i could help fellas.
02-26-2008, 02:22 PM | #12 |
Can you get it off without prying off the chrome knob part? I pried one off one time and it won't stay on any more, it just falls off whenever you hit a good bump.
02-26-2008, 11:20 PM | #13 |
I replaced mine last weekend... there's a release pin on the inside of the latch that you can take the chrome knob off with. When mine came out it came with the knob and the interior shaft.
Then I unscrewed the ring behind the lock, which separated the front from the back. The whole thing took like 10 minutes. Great pics though - would have been nice to have instead of fumbling around like a dork test fitting it!
1974 GMC C-10; my new addiction 1998 4 Runner; daily driver |
02-27-2008, 06:10 AM | #14 |
Addicted to Chevy
i couldnt get my lock ring off without taking the knob off... but yours may be differrent
02-27-2008, 06:32 AM | #15 |
You do NOT have to pry off anything. Not the Knob. Not anything.
Here is the correct way of removing it without damaging any parts. It can not be disassemble using the correct method with the latch in the open position. For key lock latches: Lock the latch with the glove box open. Use a straightened paperclip in the top hole (the hole pointing at the passenger seat with the glove box open) to push and release each of the tumblers one by one as you slowly remove the cylinder assembly. For non-key lock latches: Latch the latch with the glove box door open. Use a straightened paperclip in the top hole (the hole pointing at the passenger door with the glove box open) to push and release each of the tumblers one by one as you slowly remove the cylinder assembly. Then you can unscrew the round piece from the outer side of the glove box door. Last edited by ChevyTech; 02-27-2008 at 06:39 AM. |
02-27-2008, 06:44 AM | #16 |
Hey chevy tech can you post pics???
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
02-27-2008, 06:57 AM | #17 |
I got it!!!
02-27-2008, 07:22 AM | #18 | |
I don’t own anything that old.
Or does that mean you found other photos? |
02-27-2008, 08:53 AM | #19 |
Hey thanks chevytech I removed the cylinder assembly and I didn't pry the knob off!!!!!
02-27-2008, 09:00 AM | #20 |
Very easy!! Now I Can paint the glove box door
02-27-2008, 09:23 AM | #21 |
Thank you.
02-27-2008, 08:47 PM | #22 |
Addicted to Chevy
ChevyTech - you just HAD TO STEAL MY THUNDER, DIDNT YOU!!!!!!!
02-27-2008, 09:17 PM | #23 |
Sorry!
I don’t mean to steal anyone’s thunder. Some things are so easy when you know the tricks or methods to do, and I hate to see someone breaking parts to do it the hard way. Some of you guys have some very nice older trucks. Where I live you just don’t see many older trucks on the road and you sure can’t find any that are not rust buckets that anyone will sell for a price I would be willing the spend on one. Around here it is getting rare the see anything older then the 1988 & newer body style in the scrap yards I go to. |
04-18-2015, 05:03 PM | #24 |
I know this is an old thread, but ChevyTech's advice helped me out - thanks! Adding picture that several others asked for. My glovebox was already out of the truck when I removed the latch, but I'm pretty sure I had better access to the tumblers when it was un-latched (as shown in picture). After removing the handle, unscrew the entire rear latch assembly. You can see how its threaded on in the picture.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
04-19-2015, 10:11 AM | #25 |
http://youtu.be/MUxMxlky_Cw
Here's a video I used when I needed to remove mine to replace the liner and paint the lid. |
