03-31-2008, 10:23 PM | #1 |
electric fan advice
I am considering going to an electric fan system on my 72. I don't know much about them. I know there are some cheap ones out there, but I want to know what the best ones are. I currently have a single core radiator which i will be swapping out for a four-core. Any input on this would be appreciated.
04-01-2008, 12:06 AM | #2 |
Re: electric fan advice
there is a thread were someone used a Mopar fan for a Jeep cherokee, fit perfectly into our shroud and only cost like $75 or so...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-01-2008, 05:15 AM | #3 |
I am going to use the jeep set up but it will be a few more months before I could tell you how well it works. From initial reports it works great unless you plan on towing a lot.
check it out here- http://67-72chevytrucks.com/vboard/s...d.php?t=254617
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
04-01-2008, 06:13 AM | #4 |
.....I am working on it.....
If you want the best, get Spal fans and a tight fitting shroud.
04-01-2008, 08:28 AM | #5 |
Wes at classic heartbeat sells a duel fan and shroud that is pretty straight forward for our trucks.
04-01-2008, 02:31 PM | #6 |
Found under 'electric fans' using the search function:
http://67-72chevytrucks.com/vboard/s...earchid=762131 |
04-01-2008, 04:26 PM | #7 |
link didnt work...
vBulletin Message Sorry - no matches. Please try some different terms.
04-01-2008, 05:57 PM | #8 |
04-02-2008, 11:16 PM | #9 |
Sofa King. We, Todd, Ed.
Here's a link to a couple ideas:
http://67-72chevytrucks.com/vboard/s...d.php?t=282793
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
04-03-2008, 12:59 AM | #10 |
Project Junkie! Fishing Poor!!
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-03-2008, 02:46 AM | #11 |
I'm using the Jeep fan. So far no problems. I have it running with a 180 degree tstat probe and a manual off/on switch under the dash in case the tstat ever fails. The fan fit is perfect in the stock shroud. Also I am using a 2 row radiator. Runs between 175-195 degrees on my 383 engine w/auto. All total, I have around $55 in this setup. I got the fan off Ebay for $25.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 04-03-2008 at 02:49 AM. |
04-03-2008, 06:17 AM | #12 |
i saved a duel fan and shroud setup from a 80 or 90 somthing caddy sedan deville looks to be real close to being a bolt on deal. now to get started on the truck to see if it's as slick as it looks
common sense isn't so common anymore |
04-03-2008, 02:57 PM | #13 |
Keep in mine the amp draws on some of those fans are pretty high & your alternator might not be big enough. Just a thought...
1997 GMC Sierra Ext 1965 Mustang |
08-05-2008, 02:31 AM | #14 |
so I received the Jeep fan today... quick question...
I might sound a bit ignorant here, but.. In the FAQ thread, everybody talks about the relay and the thermal switch. Are these really necessary? Can I not just hook it straight up to ignition power, running always when the truck is running? What benefit would it have kicking on and off? Thanks
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- Last edited by dazza; 08-05-2008 at 02:33 AM. |
08-05-2008, 02:54 AM | #15 |
Built 4 Speed
th relay is for running high amperage thru a low amperage switch and the thremal switch is kind of what it states kicks on at a cetain temp and shuts off at another..
i just went with a 30 amp switch and i run the fans when im not moving.. a bit of a pain for some but eases my mind when i drive.
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
08-06-2008, 01:24 AM | #16 |
PLAY HARD.....OR DONT PLAY!
My 454BB was running cool on the street but crazy hot while wheelin, using the GM 4 row radiator. I put a dual fan set up from FlexLite pulling and wired the A/C fan to the dual set up to push (3 fans total) made it better but still a bit hot while wheelin (not good for wheelin the Calif. dessert). finally broke bread and got a Griffin (2) 1 1/4 row radiator and it made a huge difference ! Back to what was said about the alternator. After the 3 fan set up at high RPM's the stock alternator was only putting out 10 volts at its best while running the A/C, then I turn on then radio with amplifier and it went down to 8-9 volts (not good having a dead batt. in the Calif. dessert) so I had my buddy install a 110 amp internal regulated alternator. now the voltage gauge barely drops from 12-14 volt's with everything on.
IF YOU DONT HURT..........YOU NOT TRYING HARD ENOUGH. 71 CST BLAZER 4X4, 1 TON, 496 STROKER/TH400, NP205, D44/14BOLT LOCKER, 35" BFG'S,... 68 C30 292 LB (POP'S BOUGHT IT BRAN NEW) 05 2500 4X4 DURAMAX CREWCAB 79 FLH HD 95CI EVO :b69 Last edited by 71 TopCat; 08-06-2008 at 01:26 AM. Reason: forgot to mention "using the GM 4 row radiator" |
08-07-2008, 05:17 PM | #17 | |
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
08-07-2008, 08:26 PM | #18 |
Thanks 67mater... I'm in Cali so I don't really need the thermal hook-up. Would the relay be needed if I'm not going to use the thermal switch?
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
08-08-2008, 09:54 AM | #19 | |
You might as well use the thermal switch though. There is no need to run the fans at highway speed....trying to turn it on/off by hand will get old pretty quickly. Why run them when you don't need to? It is just more taxing to the charging system. |
08-08-2008, 03:03 PM | #20 |
Thanks Longhair
