04-14-2008, 08:35 AM | #1 |
Can I remove the vacuum switches?
My 2 vacuum switches I want to take them off !
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
04-14-2008, 08:40 AM | #2 |
Re: Can I remove the vacuum switches?
I want to remove em 1 in the intake manifold and 1 in the water outlet
04-14-2008, 03:29 PM | #3 |
Dirteh Kitteh
Are you talking about the thermal valves? One is orange and one is a pale green?
The help correctly control the EGR valve, your torque converter lockup (if it has it), the air valve on the air cleaner horn, and sometimes vacuum secondaries on the carb. They also control the Air Injective Reaction System (better known as the smog pump, but your being a 1975 might not have it). If you can live without all of the above, you most certainly can remove them.
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD Sign up with the Contact List RIP ESLL |
04-14-2008, 04:47 PM | #4 |
On a '75, one of them might go to the vacuum advance cannister on the distributor. Back then they were "experimenting" with switching between ported and full manifold vacuum, with a thermally controlled switch.
04-20-2008, 08:02 AM | #5 |
Maybe im wrong here's a pic of that temp sensors
