Old 04-17-2008, 05:53 AM   #1
ppscugog
5.7 L Motor Mount install question
I'm installing a 5.7 L replacement engine in my 87 4X4. Do you install the bottom part of the motor mount on the frame first (clamshell part held on to the frame with three bolts per side) then drop the motor overtop and install the single through bolts, or, install the entire motor mount on the engine while its on the stand, lower the engine into the truck, then install the three bolts per side to the frame?
I tried the first method tonight and couldn't get the engine up and over the clam shell part of the mounts. Distributor hung up on the firewall and I was afraid to put any pressure on it. Maybe the distributor should be installed after? The engine is back out and back on the stand while I get some advice.
ppscugog is offline   Reply With Quote
Old 04-17-2008, 06:19 AM   #2
lurch115
lurch115's Avatar
Re: 5.7 L Motor Mount install question
pull the distributor out and bolt the bottom half of the mounts to the frame. Then when you install the motor it may take a little "persuading" to get the motor mounts lined up, but once you do, put the single through bolts in and then proceed with reinstalling the distributor and everything else...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 04-17-2008, 02:50 PM   #3
gezn2
Yup, one of those 'levelers' that allow you to tip the engine back-and-forth helps a *lot* in this situation Unless you're planning to change the engine every week a cheap 'chinese wonder' will work fine.
There's a fair bit of 'convincing' involved in getting the holes to line up properly and getting in the guide-pins on the bellhousing, walking the engine with a crank *really* cuts down on the amount of time you spend underneath with a pry bar "effing" at it
gezn2 is offline   Reply With Quote
Old 04-17-2008, 02:51 PM   #4
slug
slug's Avatar
at least try just pulling the distributor cap off, it may get you the clearance you need.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 04-19-2008, 01:01 AM   #5
lurch115
lurch115's Avatar
i have found in the past that its easier to pull the distributor and reinstall it later than it is to try pulling out a busted one...but give it a shot if you want.
