Old 04-18-2008, 06:04 PM   #1
Eyegore
What Hump?
Eyegore's Avatar
turbo 400 guru's need help
My transmission yesterday started making the whinning noise, sounded like it was coming from the distributor at first. Since i could not locate the actual problem, I drove it around the block, and now i'm hearing grinding, and hesitation in the transmission. I did have a leak (small), but I'm reluctant to warm the engine and transmission up to check the level because of the whinning noise. Need your advice.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 04-18-2008, 08:46 PM   #2
454HO
Re: turbo 400 guru's need help
Does the fluid smell burnt? How many miles on it? I'd say it's probably time to drop the pan and look for metal shavings.
- Greg
454HO is offline   Reply With Quote
Old 04-18-2008, 08:50 PM   #3
slug
slug's Avatar
x2, i think it would be a good idea to atleast do a fluid/filter change on it. i think a filter is only like $9 and some change. it will also require 5 quarts of fluid. but, it may also have a major problem that may require a rebuild.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 04-18-2008, 09:46 PM   #4
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
Could be the front pump, if it is shifting erratic and doing strange things, the pump could be a big part or all of the problem. Your converter could have broke and now you have something caught in the pump too, seen that a couple times. If the noise changes pitch with engine RPM as opposed to vehicle mph, chances are its in the pump or related parts.
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 04-18-2008, 11:03 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
The filter and fluid were just changed les than 1000 miles ago. I had a slight leak but I worried I ran it down to much.
Lil red 86 c-10
99 Sub
Old 04-19-2008, 12:34 AM   #6
lurch115
lurch115's Avatar
had the same issue a few years ago and after the grinding noise started i made it about 3 miles and the tranny let go...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
