04-27-2008, 09:46 PM | #1 |
Door threads stripped ???????
Ok guys I am stuck I went to mount some cherry doors on my cab and found most of the threads are stripped on the door side where the hinge bolts on ......Do any of you guys have a solution for this ...anything will help thanks guys...Greg
04-27-2008, 09:54 PM | #2 |
I have a radical idea!
Re: Door threads stripped ???????
I had this problem on one of my car hauler doors. I drilled them bigger with "U" drill (.368") and retapped the with 7/16 - 14 threads. You can use a 3/8 drill but the threads are a little tighter with the "U" drill. You will also have to make the slots in the hinges bigger and wider (which isn't a bad idea on these trucks anyway). I did mine with a 1/8" carbide burr in a die grinder, but you could do the same thing with a Dremel.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 04-27-2008 at 09:54 PM. |
04-28-2008, 02:34 AM | #3 |
I have welded fine thread nuts to the inside of the mounting plate and also, retapped the threads to 7/16-20 as 67 C-30 did. Instead of opening up the slots, I machined the shank down where the slots line up with the bolt and remachined the 5/8" hex head to a 9/16" hex.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 04-28-2008 at 02:34 AM. Reason: Wording |
04-28-2008, 06:56 AM | #4 |
you guys never heard of heli-coils?
04-28-2008, 07:06 AM | #5 |
dont last long in this application i tried em years ago
04-28-2008, 08:04 AM | #6 |
04-28-2008, 09:06 AM | #7 |
Helicoils will not work because you are dealing with thin metal. What will work is a threaded insert for thin metals. I have attached a web page that has the threaded inserts. I believe that you need a 3/8-16 thread. You drill out the thread with a 9/16 drill and the insert is two pieces, one on each side of the metal and tighten the two pieces together and that sets your insert. The web site shows an insert that has been installed. Another option would be a rivet nut
http://www1.mscdirect.com/CGI/NNPDFF...8129&PMCTLG=00 |
04-28-2008, 04:39 PM | #8 |
i had one stripped out. i was in a hurry and no welder so i double nutted it and its held. it took some effort and i had to talk to it nicely and it works. Old money.
04-28-2008, 05:54 PM | #9 |
yeah i used the wrong bolts in the original holes..(rookie!!) when i was doin mine 2 years ago. i drilld out and re-tapped em, perty good still!.. ha
