Old 06-02-2008, 06:10 AM   #1
brawley
Easy Does It
brawley's Avatar
cab swap
Can anyone tell me if you can fit 60-62 cabs onto 63-66 frames? will the cab mounts line up? thanks
brawley is offline   Reply With Quote
Old 06-02-2008, 07:03 AM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: cab swap
I've never heard (read) anything to the contrary. I'm 99% sure they'll swap, but I'm sure someone else on here can offer up that last 1%
Frizzle Fry is offline   Reply With Quote
Old 06-03-2008, 11:47 PM   #3
brawley
Easy Does It
brawley's Avatar
Re: cab swap
Has anyone ever tried to use the 60-62 cabs on 63-66 frames? I also wondered about 55-59 cabs on these frames, has anyone ever atempted to do this? thanks
Old 06-04-2008, 01:30 AM   #4
joe231
joe231's Avatar
Re: cab swap
i believe i read somewhere that 2 cab mount don't line up between '60-'62 and '63-'66, but it is only metal, anything is possible
CHEVY ONLY
Old 06-04-2008, 07:34 AM   #5
scotts62
One day...
scotts62's Avatar
Re: cab swap
Not 100% sure but the front mounts on my 62 are farther out from the frame compared to joes (64?) that was the only difference that i have seen. But i do agree with joe about, its only metal
Scott
93 crew cab build
Project 62
Old 06-04-2008, 08:00 AM   #6
62 short step
62 short step's Avatar
Re: cab swap
Yep, the 60-62 front cabmounts or diff from the 63-66. Just need to change the front mounts when you do the swap. the 60-62 frames are wider so they use a little longer cab mount. I've done it no big deal. Just unrivit the mounts and bolt them with grade 8 hardware.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 06-04-2008, 08:40 AM   #7
joe231
joe231's Avatar
Re: cab swap
this one is a '66, my waiting project is a '64
CHEVY ONLY
