Old 06-12-2008, 08:23 AM   #1
drasticwagon
drasticwagon's Avatar
Centerline Smoothie Problem
I Have them on my 65 and on my 67. I battled Centerline for the longest on the center caps for the front and gave up. I have a mess load of center caps that they sent me thru out a 7 month period that will not work. I know I might be able to go with the bigger style cap rather than the rounded at the top cap , seen it on a few. I'm not sure that my wheel will fit them though. Has anyone found a smaller hub or grinded it down a little before? Just curious , I gave up for a while but now I want to fix the problem again.
Thanks for the help....
drasticwagon is offline   Reply With Quote
Old 06-12-2008, 12:34 PM   #2
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
Re: Centerline Smoothie Problem
I had center lines on my truck and I ground down the hubs to make the cap fit. I removed the brake calibers & studs replaced the hubs and used a side grinder to grind them down.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 06-12-2008, 06:05 PM   #3
drasticwagon
Thanks for the info , appreciate it.
Old 02-13-2010, 07:07 PM   #4
lyrikz
PITbut
lyrikz's Avatar
What did you end up doing. I put my centerlines on the front for the first time today and ran into this issue. Wont go over teh hub. Any ideas.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
