Old 06-14-2008, 09:53 AM   #1
Wolfinthesnow
Wolfinthesnow's Avatar
Frame Converted
Finally got all the body mounts off the truck frame and onto the suburban frame im using. After cuttin off somewhere around
18-24"(cant remember) off of the tail, it was nearly Identical. Minus the different cab mounts and lack of bed mounts. Moved the center cross member back also, gonna use that for my 4 link im putting in. Check it out. Oh yea, question for you suburban guys. When we tried to flip the frame to work on the other side, obviously it was heavy. Took 3 of us to do it. But the short bed truck frame... I can flip it on my own. Why and what makes the suburban frame so heavy??
I dont care how you did it in California!!!
Wolfinthesnow is offline   Reply With Quote
Old 06-14-2008, 11:16 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Smile Re: [B][/B]Frame Converted
Maybe you were worn out from flipping the other frame first?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-17-2008, 11:43 AM   #3
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 06-17-2008, 05:21 PM   #4
gulfcoast66
64-66 CHEVY JUNKIE
The 66 frames are not that light weight. It takes two to turn mine before, it was no party doing it! Good luck with your project..
Old 06-17-2008, 09:24 PM   #5
joe231
joe231's Avatar
what year suburban frame you using?
CHEVY ONLY
