Old 07-24-2008, 03:10 AM   #1
1969 k/10
1969 k/10's Avatar
Detroit locker
Is the locker really that bad on the street?
I have a 1969 k/10 so its only a half ton and was wondering how bad the clunking would be.
Also has anyone had any experience with the Detroit soft locker??
1969 red k/10 with sb350
4.11 gear ratio, front disk, 3 speed automatic
1969 k/10 is offline   Reply With Quote
Old 07-24-2008, 05:55 AM   #2
Re: Detroit locker
I run lockers alot and have no problems.When pulling out making a turn I just go real easy until I`m straight.When I`m moving and come into a sharp turn I drift through.I only turn the inner tire when I want to.I notice no rapid wear and I also rotate every 5,000 miles since the front requires that anyway.
Old 07-24-2008, 10:40 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Detroit locker
My 69 K20 has a factory No Spin which is a Detroit Locker in the rear axle. It does make a bit of noise occassionally and the first few times you hear it surprises you and you wonder what that was - then you get used to it. Drive like special-K says and you'll be fine. Be aware that you are running a locker when it is icy or snowy out. I came out of a store drive one day and there was a little moisture on the road and got spun around about 90 degrees real quick when the rear axle locked up - that is the only time it has grabbed my attention.
I'm running a new Detroit Locker in the 14 bolt I have in my 70 K5 and I find I notice it alot more. If I'm on the highway and go to coasting I can feel it unlock and when I get back on the gas it definitely pulls a bit to one side for some reason. I think that is actually becoming less of an issue the more miles I put on that Detroit Locker.
Yes your going to have an occassional clunk but it is all worth cause when you need both wheels getting full traction - the Detroit Locker is there for you!
I've never ran a locker in a front axle, however, I think your question is directed at one in the rear axle anyway.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-24-2008, 11:26 AM   #4
AJs72K5
AJs72K5's Avatar
Re: Detroit locker
I put a Detroit in the 14FF on my K5. Hardly ever notice it's there. But, like YJ said, it is a lot easier to get squirrely when the road is slick from rain, ice, or otherwise. Overall very happy.
On a front axle, a locker doesn't make any difference until you lock the hubs. The hubs freespin on the spindles until you lock 'em on the axle shaft. That said, ARB's, OX's, e-locker's, etc. function in an "open" mode until you engage the locker.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 07-24-2008, 01:58 PM   #5
1969 k/10
1969 k/10's Avatar
Re: Detroit locker
What about the cheaper lockers like lockright?
Is it worth spending 300$ less or will it break easily?
Old 07-24-2008, 02:15 PM   #6
AJs72K5
AJs72K5's Avatar
Re: Detroit locker
I went with the Detroit for strength and reliability. A lot depends on tire combo, how much engine you have, and how you intend to drive it.
- AJ
Old 07-24-2008, 02:24 PM   #7
1969 k/10
1969 k/10's Avatar
Re: Detroit locker
I have a 350 and its like 70% street 30% off roading. I'm running 32in. tires.
Old 07-24-2008, 08:04 PM   #8
LONGHAIR
Re: Detroit locker
I ran one in a K/20 with a 14 bolt FF and 40" tires for several years. That truck also had a Tru-Trac in the front. It was a blg-block 4 speed too.
Even with the long bed and big heavy tires, you knew it was back there.
Like the others have said, if driven with respect, they are fine. You just have to be cautious about who you let borrow your truck, they would not be aware of this type of thing.
I have driven other trucks, w/lockers, that had automatic transmissions. These are a little more forgiving because an automatic keeps more load on the driveline. While the clunking may be less noticable, the wet-weather traction issues are still there.
LONGHAIR is offline   Reply With Quote
Old 07-25-2008, 01:37 AM   #9
1969 k/10
1969 k/10's Avatar
Re: Detroit locker
Do they make an e-locker for a 12 bolt?
Old 07-25-2008, 02:11 AM   #10
1969 k/10
1969 k/10's Avatar
Re: Detroit locker
Has any ever ran a no-slip locker from powertrax?
Is it more street friendly? Does it also give you 100% lock up??
Old 07-27-2008, 04:47 PM   #11
6872xtc
6872xtc's Avatar
Re: Detroit locker
Yes you can get an E-locker for the 12 bolt, their rep told me that it has a tire size limit, but didn't say what. I know from experience that you would be fine with a soft-locker or Lock-right, (drop in style locker). I have not seen any problems with your engine, trans and tire set-up. Like everyone says, remember it on wet or slick roads, but they are very easy to get along with on dry pavement to me.
6872xtc is offline   Reply With Quote
Old 07-27-2008, 10:13 PM   #12
CPNEJR
CPNEJR's Avatar
Re: Detroit locker
i too am interested in getting a locker and was wondering if they make them for eatons and what is better than another w/o spending a ton of money
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 07-27-2008, 10:39 PM   #13
Re: Detroit locker
I`ve bought used No-Spins for $100-$125 off this site.The ones I`ve seen lately were more like $300.I think that`s kinda high since most guys are going to 14-bolts when there`s a problem with the HO52.New unit`s aren`t available.
Old 07-28-2008, 07:35 AM   #14
BIG HEAD
Re: Detroit locker
dont just go buy a locker without knowing what gear you are going to run. the gear size will matter on the locker. a 4:56 gear may not work in a locker set up with a 3:73.
BIG HEAD is offline   Reply With Quote
Old 07-30-2008, 05:47 PM   #15
1969 k/10
1969 k/10's Avatar
Re: Detroit locker
Where can a find an e-locker for a 12 bolt??
Old 08-07-2008, 04:11 AM   #16
1969 k/10
1969 k/10's Avatar
Re: Detroit locker
Has anyone ever tried the auburn ected before?
When you engage it, is it a full locker or just a glorified limited slip.
