Old 07-28-2008, 12:48 AM   #1
DESTRO
help with stuck ball joint sleeve
Hello,
Anybody got any tips or tricks to get a dana 44's ball joint adjusting sleeve unstuck?
It's a 77 and it looks like their the original ball joints and I live in the rust belt.
Please share how you got yours out.
DESTRO is offline   Reply With Quote
Old 07-28-2008, 06:33 AM   #2
Re: help with stuck ball joint sleeve
Press...may need heat to break rust.
Old 07-28-2008, 08:08 AM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
The upper ball joint adjusting sleeve?
Do you have the special adjusting sleeve spanner socket?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-28-2008, 04:32 PM   #4
Blazer1970
Blazer1970's Avatar
You do need to separate the ball joints from the knuckle before you remove that sleeve. That may be what you are doing, but I have seen people try to turn the adjusting sleeve out with the ball joint still stuck in the taper and you will never budge it then. Usually once the ball joint is out the sleeve turns out easily since it is slit all the way down one side.
Blazer1970 is offline   Reply With Quote
Old 07-28-2008, 11:06 PM   #5
DESTRO
Well I guess I should of given alittle more back story.
I have the entire front tore down ,ball joints out and the knuckle on the bench.The adjusting sleeve is the only thing left to remove.It's super stuck.
The spanner is useless,It just keeps popping out. Tried knocking it around with an air hammer. Heating it with propane. PB blasted it. Even tried melting some wax. No dice on any of it.
Had the wife get me some Mapp gas today.Might try to heat it up and try to air hammer it in on it's self. Gonna be a couple days till I get to it so hopefully I get some good ideas. Did I mention, I think these are the 30+ year old originals??
They are kicking my butt.....PLEASE HELP
Old 07-29-2008, 07:06 AM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
Can you get a oxy/acetylene torch? Heat the knuckle, not the sleeve. Pb blaster. Try and turn it with a punch and hammer. The air chizzle sounds like it would booger up the threads.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-30-2008, 01:15 PM   #7
HotRodYJ
HotRodYJ's Avatar
I've had to break them out before with a chisel then just install new ones. Just be careful not to damage the threads.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 07-30-2008, 11:13 PM   #8
DESTRO
I was thinking about doing that. I'm in the middle of hunting up some fire wrenches.Atleast this downtime is giving me time to paint the parts I took off.
I am grateful of all previous tips and hope to get some more.Hopefully those torches come buy this weekend.
Old 07-31-2008, 11:42 AM   #9
Burt4x4
Burt4x4's Avatar
One thing I did was held the spanner socket down w/clamp (duct tape on tight works) and then a long braker bar w/jack handel and stand up and push/pull, the clamp held the tits into the slots....errrrrrrrrrrrrrrrrrrrrrr it came out
good luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-01-2008, 02:21 AM   #10
DESTRO
I actually tried that with a C-clamp to no avail.
Well I got that sucker out. Had a friend come over with torches.he's done plenty of these in the past and said that he's never seen one this stuck before.
Here's a trick I'd like to pass on....If it's stuck,find the slit in the sleeve and directly across it on the raised nub drill a small hole down thru the sleeve.With either a small chisel or a steady hand with the fire wrench,cut down the edge of the hole.Now you have 2 halves.Tap the one half in and it will loosen up.Carefully wiggle out the half.Sometimes heating the edges and curling in the edge will help fish it out.
Hopefully this helps someone out...I know it helped me.
Old 08-01-2008, 07:24 AM   #11
OLDCHEV4X4
OLDCHEV4X4's Avatar
Do you need to chase the thread? Or is good to go.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-03-2008, 11:03 PM   #12
DESTRO
Yeah,I had to chase it.Not from what I did but the 1st thread was collapsed.
It's a 1-1/8 x 12 tap if anyone was interested.
