08-30-2008, 06:44 PM | #1 |
Active Member
WTB, double groove water pump pulley, I-6
Bought one from a board member that we both thought would fit on a 250 even though it came off a 292. When I tried to bolt it on my 250 it hits the water pump before it even gets close to being bolted tight.
Anyone have the correct water pump double pulley for a 250 with power steering? Thanks, Mike D.
The older I get, the faster I was!! |
08-31-2008, 04:09 AM | #2 |
Always on the hunt...
Re: WTB, double groove water pump pulley, I-6
Hey Mike, I have a few different I-6 wp pulleys around here, can you make out a part number on the pulley that you just tried and confirmed as not going to work? IIRC, you are going to need a two groove pulley with the pn ending in 7796, let me know if that is the one you just tried.
08-31-2008, 08:07 AM | #3 |
Active Member
Classic,
I think I found locally with the part number that you mentioned. I'll let you know. Thanks for your quick response. Mike D.
08-31-2008, 11:26 AM | #4 |
08-31-2008, 12:03 PM | #5 |
Active Member
3942992BA
It did come off a 292. If I remember correctly, 292's have a slightly longer impeller shaft than the rest of the I-6 family. That would explain why this one won't work for me. Mike D.
09-15-2008, 01:11 PM | #6 |
I have a 292 that I want to add air to is the pully that I need??
09-16-2008, 07:50 PM | #7 |
Active Member
I believe it is.
$45 includes shipping to the lower 48 Let me know, Mike D.
09-18-2008, 11:23 PM | #8 |
I'll take it. shoot me a pm
