Old 10-15-2008, 10:30 PM   #1
HoupPhotography
Starting Problems
I have a '67 bagged LWB fleet, I just bought a new compressor and hooked up some new switches and had no problems.
The problem that started today, when the truck is layed out, it wouldn't start, like I had a dead battery. I tried ti jump it and no luck, so I put air in the front bags to look underneath, didn't see anything, and deceided to try and start it again, and it fired right up.
When I made it home, I looked for pinched wires or anything that could be tight and didn't find anything but I noticed my starter was pretty hot. Is it possible that I need a heat shield around the starter & possibly the main power wire? Is there anything I should look for that may be getting smashed? I also have my battery in the bed.
summary.....
Layed out = no power
Front aired up = power
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 10-15-2008, 10:42 PM   #2
jorgensensc
jorgensensc's Avatar
Re: Starting Problems
Sounds like something is grounding out. Or when it is aired out is is pulling on a power or ignition switch wire. Just some starting points.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-15-2008, 11:03 PM   #3
HoupPhotography
Shawn
I was thinking the same thing, finding it is the hard part.
I appreciate the inout man, thank you!!!
Old 10-15-2008, 11:22 PM   #4
El Jay
Gone to greener pastures
I can't help you on any of this bagged stuff, Houp.
I just noticed that you hadn't seemed to post anything for a while, so I was beginning to wonder/worry about you.
Glad to see you're still alive & kickin'!
El Jay
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 10-15-2008, 11:33 PM   #5
HoupPhotography
El Jay
Hey thanks man! I'm still here, I've been super busy shooting and I can finally work on my junk since it's not 150 degrees outside. Between that and the ol' Doc telling me I need exercise & diet to get my Tri-g's, BP & cholesterol down, so I had to dedicate some time in the day for that too.
The funny thing is, I WAS only 15 lbs over my "reccomended" weight but it's in the gene's....lol!
So any who, how the heck have you been man?
Old 10-16-2008, 12:39 AM   #6
El Jay
For an old guy, I've been doing all right, mostly.
I've been a little remiss in taking my BP meds, and the last few days I have'nt felt "quite right."
So this A.M., before I headed off to work, I checked my BP: High 150's over low 90's. Resting pulse rate 110+.
I jumped on the ol' meds like; "White on rice, dots on dice, cool on ice!!!"
Silent killer my a$$! My body knew to tell me something.
That's about it for now.
Don't be a freakin' stranger.
PM, or email, just to say, "Hey, I'm still alive"
El Jay
Old 10-16-2008, 01:01 AM   #7
mr48chev
mr48chev's Avatar
The starter may have bad bushings and be dragging when the engine is hot.
I just changed the starter in my wife's Caddy yesterday for the same thing as I was a bit in too much of a hurry to take time to replace the bushings and brushes. The local "homies" in town were impressed that an old white guy knew how to hit a starter with a rock while one of them turned the key to get the car to start.
Bushings and brushes to rebuild the starter cost under 10.00 at NAPA and it doesn't take too long to rebuild one. Usually what happens is that the drive end bushing gets worn and the armature drags on the fields when you go to start the car and it worse when the engine and starter are hot.
Other than that go through the system with a volt meter and check for voltage drops at the connections.
Often the ground connections are the problem and overlooked. Make sure that the ground connection to the block is to "bare" metal and is "tight".
Old 10-16-2008, 05:36 AM   #8
umwtnt
umwtnt's Avatar
It sounds strange that it occurs when you lay out. Have you checked all your wiring to make sure nothing is shorted or grounded out. Your starter can get extra hot if the wiring is not right. I would check all the wiring to the starter to ensure nothing is touching where it should not be. Also the ground wire is extremely important. Battery to engine, engine to frame and to the cab. It sounds like something is amiss with the wiring. I would also touch every inch of each wire to the starter, to many times I have called myself looking and missed the problem, by physically touching the wire from start to finish, you can ensure yourself that the wires are okay. Good Luck.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 10-16-2008, 05:11 PM   #9
HoupPhotography
Thank you guys for all of your input, I'm going to dive into it tonight.
Old 10-16-2008, 05:51 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Some interesting comments.
When you tried to start it, did you get a click?
Did the BRAKE light in the dash come on?
Did any other electrical parts work?
Had you just driven it to the spot you were at, dropped the truck, and then tried to start it?
How long between when you tried jumping it, and when you got it to start?
I have a few ideas on what to look at, but some of these questions would direct me in one way or another.
Old 10-17-2008, 12:30 AM   #11
HoupPhotography
When you tried to start it, did you get a click? NO
Did the BRAKE light in the dash come on? I'm not 100% but I don't think so
Did any other electrical parts work? NO
Had you just driven it to the spot you were at, dropped the truck, and then tried to start it? YES
How long between when you tried jumping it, and when you got it to start? Maybe 15 20 minutes
Thank for your help!!!
Old 10-17-2008, 05:34 AM   #12
Longhorn Man
take a real close look at the small wire that goes from the positive to the small terminal on the fender, then the small wire from said terminal, and up to the main harness and fuse box. see if something is pulling on it and making it lose contact.
Old 10-19-2008, 09:36 AM   #13
67sss
67sss's Avatar
not to rob a thread, but what is the small fuse able link that comes off the fender used for? will a engine start and run without a fuse-size unknown- in it?
67sss is offline   Reply With Quote
Old 10-19-2008, 10:47 AM   #14
Shyguy
Junior Member
Shyguy's Avatar
If that is the wire that I am thinking of it supplies 12 volt to the rest of the truck.
I am not sure what size the fusible link is though.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 10-19-2008, 10:57 AM   #15
HoupPhotography
I finally fixed/found the problem...Thanks to Longhorn man. I did follow the small wire and discovered two major issues; one the main cable was burnt and two the posotive terminal is a 2 gauge wire and reduceds to 4 under the truck between the bed and cab (the battery is in the bed) I deceided to unwrap the electrical tapejust to inspect the connections, and the crimped end was only hanging on by the electrical tape
Old 10-19-2008, 11:48 AM   #16
Longhorn Man
good deal, glad you got it man.
Old 10-19-2008, 02:27 PM   #17
corn
I think it was grounded out! Get it? Cuz you said you had it aired out... ya know...on the ground...ummm yea
Ohhhhh, nevermind...
corn is offline   Reply With Quote
Old 10-19-2008, 03:10 PM   #18
HoupPhotography
Me too, thanks again man!!
Old 10-19-2008, 04:39 PM   #19
Longhorn Man
that's what this whole board thing is all about!
