Old 10-17-2008, 08:58 PM   #1
Knot at Work
Brakes fade to soft
Hey fellas need a little help.
I have a 72 C10 LWB. I have disc front and drums rear. NO PWR Brakes and NO PWR steering. Brakes have slowly started to fade over the last few weeks. Usually no problems pumping and getting pressure and after a few miles downm the road Brakes stop well but when at idle and stopped pedal drops all the way to the floor, sometimes slowly, sometimes quickly, a few quick pumps get brakes working again.
Frequency is increasing.
Thoughts?
thanks
Knot at Work is offline   Reply With Quote
Old 10-17-2008, 09:36 PM   #2
cdowns
cdowns's Avatar
Re: Brakes fade to soft
sounds like a bad master cylinder. have you checked the brake fluid level lately?
Old 10-17-2008, 10:51 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
pull the carpet (or rubber matt) back on the drivers side. Is there a wet spot rolling down the inside firewall eating the paint.
If so... go to the parts store and get a new master cylinder.
if not... bleed the brakes and adjust the rear shoes up.
Old 10-18-2008, 01:45 AM   #4
LuckyHenriksen
LuckyHenriksen's Avatar
Mine did the exact same thing and it was a bad MC
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 10-18-2008, 01:45 PM   #5
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
Yep, I agree. MC aren't hard to replace. The just look hard. You can do it in an hour with two guy (you and a friend, a son, a daughter, your wife etc) Bench bleed the MC. Install. Bleed the lines. Your good to go.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
