11-23-2008, 02:08 AM | #1 |
I think she **** the bed....
I took my beloved truck for a B-double-E-double-R-U-N, on the way home it sounded kinda funny, like someone threw a bunch of ball bearings in the crankcase....I got home, killed it, and let it cool down. I checked all the fluids, everything was ok, and then I cranked it up again. It started up right away like all was well, but as soon as I hit the gas it sounded like holy hell...clack clack like I was doing serious harm to the innards of the motor...
it's an original 350, 120k miles, no mods...sounds d-e-d to me... this is my grandpa's truck...I don't want it to die on my watch.... |
11-23-2008, 03:41 AM | #2 |
2WD 4 Life
Re: I think she **** the bed....
it doesnt cost much to rebuild one of these 350s man...
Big D 1969 c10 1960 cadillac 1978 king cobra |
11-23-2008, 04:06 AM | #3 |
Moderator
I say resurrect the ol' girl. Rebuild the engine, or get a crate engine.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
11-23-2008, 10:41 AM | #4 |
I want to but funds are beyond tight right now. What's a ballpark rebuild cost?
11-23-2008, 12:03 PM | #5 |
Robert Olson Transport
im going to play devils advocate here..
first off next time youre going on a B double E double R U N send George or Garth... its their turn anyway Did you recently have an oil change done? Did you use a jiffy lube kinda place? I had a problem like that with a Ford F 250 and it turned out the oil filter would jam and not allow the oil to flow... You may have pushed the truck to the limit and hurt the motor but id take a $3 chance and change the filter.. and for laughs pull down the pan and make sure the screen and all is clear... if that dont help then you have to rebuild or replace the motor You can get a crate efor around $1500 or rebuild the one you have for about a third of that ( stock kinda motor) or you can get a good used motor for about $300 or so whatever you do good luck
11-23-2008, 12:17 PM | #6 |
I didn't just change the oil, or anything for that matter. I rarely drive the truck, maybe 3-4 times a month, and I check the oil/trans fluid/coolant regularly. Nothing out of the ordinary happened.
I made a run to Target for some Christmas lights earlier in the day and it was fine. When I left home to go to the corner store, I left the truck running while I went in. From inside the store I could hear that something was wrong...but when I got in it and gently touched the gas it sounded fine. If I really rev the engine it sounds like it's going to explode. |
11-23-2008, 01:03 PM | #7 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-23-2008 at 01:04 PM. |
11-23-2008, 01:45 PM | #8 |
Like Scoti said "isolate" the noise. Is it a broken balancer that has come off of the rubber? What about converter bolts. Look to see if the carb stud is there. Pull the plugs and see what they look like. If they are looking good then its nothing in the cylinder. Just check all the small stuff first.
11-23-2008, 02:23 PM | #9 |
Sb 400 club
Yeah and a solid used motor locally can be had for under 300.00.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
11-23-2008, 02:53 PM | #10 |
If you nedd a shortblock you can get one from Kragen or just about any auto parts places for under $1000. I just priced a reman long block for my 84 with a 305 and it was $1300. I`m building a 350 for it but I was just curious. I can get a new crate 350 from the local chevy dealer for $2000 which seems high to me but he`s got them in stock with no core needed.
Anthony |
11-23-2008, 09:59 PM | #11 |
comfortably numb
I had one do kind of like that once. The torque converter bolts were loose, and trans had never been pulled. Had to replace the converter and flywheel.
1974 gmc 3/4 t. c/s 1974 chevy k-10 1973 pontiac grandville(turnpike cruiser) Last edited by j hannah; 11-23-2008 at 10:00 PM. |
11-23-2008, 10:34 PM | #12 |
78 Big10 454
Don't forget to check out the motor mounts, too.
11-24-2008, 09:06 AM | #13 |
Right turn Clyde
Cracked flexplates are also somewhat common
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
11-25-2008, 01:38 AM | #14 |
i'm gonna say its probably a spun rod bearing but i agree with what these guys have said...locate atleast the general area where the sound is coming from.....another thing not meantioned yet is possibly a half shredded belt, or the transmission bellhousing bolts....can't tell you how many times i have slid under a truck or car and found that the tranny was loose on the motor....they my look tight, but put a wrench or socket to them anyways
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
11-25-2008, 08:28 AM | #15 | |
As for getting a motor for it, You might want to check around with your local guys, There is a guy I know had a mildly built 350 for about $500 bucks. Which was a good deal. There was nothing wrong with the motor, I'd heard it run. Good luck with it. |
11-25-2008, 12:42 PM | #16 |
If you end up pulling the pan, you might want to pull a few rod caps and check the bearings. If they are bad but the crank isn't scored, maybe you could get by with a new set of rod bearings. I say this because you said, "money is beyond tight."
I can still count my vehicles on two... wait three hands. |
11-25-2008, 12:53 PM | #17 | |
Step Brother
11-26-2008, 11:24 AM | #18 |
I think it might be something to do with the fan.
when I rev the truck, no matter how high, it sounds fine going up, but once it revs down it makes the noise. Also, when I kill the motor, it makes the sound after it's off. Like as the fan spins to a stop. I'll try to get a video. Sorry guys, I'm a good motorcycle mechanic but this is the first real wrenching I've done on a real Truck, besides basic stuff. |
11-26-2008, 12:33 PM | #19 |
here's a video of it running.
watch the entire vid. When I kill the motor at the end of the video you can really hear the noise. The engine is off, but the noise continues until the fan stops. I think it's the fan....thoughts? |
11-26-2008, 01:32 PM | #20 |
It does sound like you've got a loose fan, Somethings wrong with it. I remember me and my Dad replacing a fan on something over a simliar sound.
11-26-2008, 03:12 PM | #21 |
fan clutch from autozone $20
sweet |
11-26-2008, 03:25 PM | #22 | |
11-26-2008, 05:16 PM | #23 |
ok, I figured it out....duh.
power steering was leaking and is bone dry! It probably seized up. All the same, I'm gonna fill it up and see what happens, then probably look for a new pump. thanks guys |
11-26-2008, 05:28 PM | #24 |
Well I'm glad you found out what it was. Think of it like this. A powersteering pump is a whole LOT cheaper then a motor!
11-28-2008, 03:22 AM | #25 |
Moderator
Happy days! Congrats on not needing a rebuild!
