Old 12-14-2008, 09:11 PM   #1
72gmcshorty
72gmcshorty's Avatar
Which bag for rear?
I've noticed some people using a sleeve and others using a bag for the rear (my ride is a 72 2wd blazer). Whats the difference/ benefit/ which ones easier to install, etc. Thanks
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 12-14-2008, 09:44 PM   #2
ENHANCED AIR RIDE
Re: Which bag for rear?
Either way works fine and in a Blazer will ride OK. Easiest is if t/a's will be reg double convoluted on the arms, to get low that is.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 12-14-2008, 11:07 PM   #3
Twisted Minis
Twisted Minis's Avatar
If you are putting the bags in a leverage setup, like on a link bar or cantilever then a convoluted bag will do well. If you are mounting the bag directly to the axle I prefer to run a sleeve bag. The ride is much better because of the spring rate.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
