Old 12-15-2008, 05:43 PM   #1
MBurns326
MBurns326's Avatar
Radiator Help.....AGAIN!
Ok I'm enlisting everyone's help again. So I've had a time trying to get a new radiator in my truck. I switched from the 2 to 4 core, bought new retainers and pads, go everything hooked up and realized that there was no place on the radiator for the heater hose. I contacted RockAuto (where I bought the radiator) and they contacted Spectra Premium (the company who made the radiator) and they said that the radiators are not built with an outlet for the heater hose and it has to be rerouted. The kicker is that the guy from Spectra Premium didn’t know how to reroute it. He said it makes the heat more efficient, but was no other help.
Anybody know how and where to reroute the heater hose?
Thanks in advance!
Camouflage 1971 Chevrolet C/20 2WD
MBurns326 is offline   Reply With Quote
Old 12-15-2008, 05:48 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Radiator Help.....AGAIN!
Reroute from the water pump and intake manifold. It's raining here, maybe later I'll be able to get out and take a look at the exact routing.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-15-2008, 05:56 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Went out and checked. Water pump to upper fitting at firewall, intake manifold to lower. I have factory air though so it might be a different deal with just heat.
Beat it to fit,
Old 12-15-2008, 05:57 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There will be a plug on the passenger side of your water pump, just above the radiator hose. It is 1/2" NPT. You will need a bib that screws in place of that plug appropriate to your heater hose size.
Old 12-15-2008, 06:02 PM   #5
MBurns326
MBurns326's Avatar
It may be asking a lot.....but can anyone take a picture of what it looks like?
Old 12-15-2008, 06:22 PM   #6
Tx Firefighter
He is a picture of my 350 in my step. I circled the plug in blue. Just unscrew the plug and screw a fitting into place.
Old 12-15-2008, 06:34 PM   #7
MBurns326
MBurns326's Avatar
Thanks that helps a lot! One other thing....what advantage does that have over being connected to the radiator?
Old 12-15-2008, 06:54 PM   #8
truckdude239
truckdude239's Avatar
nothing better about it. heere is how mine is hooked up
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-15-2008, 07:23 PM   #9
Tx Firefighter
It gives faster heater warm up due to the heater core water returning to the engine rather than the radiator. The theory is that the heater water basically stays in the engine and heater core rather than involving the radiator until the engine warms enough to open the thermostat.
