12-20-2008, 11:41 AM | #1 |
Headlight/alt. Wiring harness question
I am installing the original h/l wiring harnessfrom the 68 gmc. this h/l wiring harness does not have wires for the side marker ( the 68 just had a blank) can I splice into my front park/signal wires or should I try to get a harness that already has them(69-72) I think?
My other question, I installed a new alternater ACDelco p/n 19151858 with a built in voltage regulater that just needs a hot wire to ignite it, how do I wire it? the hot wire to the old alt.? & do I use any of the wires from the old voltage regulater? any help is appreciated. |
12-20-2008, 12:42 PM | #2 |
Sierra Grande Club
Re: Headlight/alt. Wiring harness question
That is a good looking truck. Your harness has seen better days & would recommend a new harness from M&H to complement your nice looking truck. There are a few venders on here that sell them too.
You'll be able to update your harness to include the internal alternator, electric choke (if you want) side markers like you mentioned plus you can get the headlight relay too. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-20-2008, 06:15 PM | #3 |
Thanks, sport/truck for the compliment & info. I'll jump to the parts board for further assistance.
12-20-2008, 07:51 PM | #4 |
Phone's ringin Dude.
Hey dad, what brackets are you using for your alt? All of the articles I've seen say that the upper bracket requires modification. BTW- here's and article with all you need to know about internal alt's--LINK
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
12-21-2008, 12:06 AM | #5 | |
Sierra Grande Club
s/t
12-21-2008, 12:34 AM | #6 |
You only have to modify the upper bracket if you are using the higher output 'cs130' alt. I'm not sure if thats what he has, guess I just went off half-cocked.
