Old 12-28-2008, 04:03 PM   #1
Helidoc
Helidoc's Avatar
700R4 swap to TH350
Ok going to pull the 700R4 and install a TH350. I can't seem to hook up the TV cable to the 4BBL so I doing some "Horse" trading. anyway it is a TH350 with lockup. Other than crossmember do I need a new flex plate? What about Drive shaft lenght? What stall should I get? It is not a daily driver just sunny weekends. Thanks for any help.
68 C10 2WD 250 6cyl Clifford 4bl, Edl Carb, Headers, work in progress
Helidoc is offline   Reply With Quote
Old 12-28-2008, 04:09 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: 700R4 swap to TH350
Why would you do that, you can get all sorts of TV cable brackets to make it work, even if the cable is too short you can get longer ones
Try this site, IIRC they have a write up on how to solve your problem
http://www.inliners.org/
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-28-2008, 04:15 PM   #3
Helidoc
Helidoc's Avatar
Hello I have the Clifford intake and with the 4BBL sitting side ways I have no room for the TV brackets and cable hookup. I called and talked to Bowtie Od and the bracket they have doesn't fit between the carb and valve cover, I had to replace the solid linkage for the gas pedal for the cable lokar type. I just have asked everyone I can think of and study ways to do until I'm crosseyed.
I know that you can by long cables and different brackets, but so far I have struck out on the install.
Old 12-28-2008, 04:47 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
As long as you use a 9 inch tailshaft TH350, you won't need to modify the driveshaft or yoke at all.
Same flexplate too.
Just move the crossmember forward and bolt it back down. The holes should be there from the factory.
Old 12-29-2008, 11:50 AM   #5
Helidoc
Helidoc's Avatar
Thanks Tx that was what I needed. I sure hate to admit when I'm defeated.
Old 12-29-2008, 06:32 PM   #6
Tx Firefighter
Brother, you aren't defeated till you quit the fight.
Do me a favor first, send a message to member ironbuttlcmc on this board. He had a 700R4 behind his inline 6 with the aftermarket intake and carb like you have. He made it work somehow and I'm sure he'd be happy to get you going in the right direction. He's a heck of a guy that way.
Old 12-31-2008, 12:45 AM   #7
Helidoc
Helidoc's Avatar
Ok going to order parts and see if this bracket and cable will work to keep the OD, Will post pics. Still anyone here who has done this swap with my setup your help would be greatly appreciated. Thanks
Old 12-31-2008, 01:13 AM   #8
Gray Ghost
Gray Ghost's Avatar
Cool post your pics when you're done...you should get decent mileage with that combo and be able to jump some v-8's off the line!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-31-2008, 07:06 AM   #9
Tx Firefighter
Did you message the member I mentioned above to see how he did his swap ?
Old 12-31-2008, 10:51 AM   #10
pumpkin
pumpkin's Avatar
On some older gm cars, around about 1975 ish, they hooked the cable to the gas pedal inside the vehicle. You would still have to hook up the cable if you use a th350.
pumpkin is offline   Reply With Quote
Old 12-31-2008, 12:03 PM   #11
Helidoc
Helidoc's Avatar
TX are you sure that name is right It said screen name invalid. I did IM an iron-butt but his work was done on a BB.
